The Missing Brake Fluid Mystery Depends
RAC68
A couple of weeks back I started a thread about a lower level in both the clutch and brake portion of the sections of the reservoir. As a result of forum suggestions and physical investigation, only slight sweating was found in the clutch slave and, although it didn’t seem equal to the reservoir loss, the missing fluid could easily have leaked onto the road during a drive. A quick rebuild of the slave cylinder and the problem was eliminated….so I thought.
This past Saturday, preparing for a club show drive, a pre-check of the reservoir showed the brake section was close to half below proper level. This was doubly concerning as a quick check found no lost fluid or any indication at each wheel or line.
Today, I decided to do a thorough investigation and started with de-installing and dismantling the brake booster. I chose the booster since it is the only place that the missing fluid could collect (in the air piston chamber) and stay incognito. Contrary to anticipation, no fluid had collected inside the booster.
One last point, the only place I haven’t considered is the brake master cylinder. The reason for my confidence in the M/C is that no seepage was indicated and no loss of pressure was noticed when applying the brakes.
Since I have already ordered the rebuilding kits for the booster, rear wheel cylinders and calipers, I will continue on that plan. However, I would appreciate any ideas as to where this fluid could be escaping as the brakes were functioning perfectly prior the dismantling.
Thanks all,
Ray (64BJ8P1)
TimK
"Depends" in title should be edited to "deepens".
But what about the engine vacuum which powers the booster drawing brake fluid into the engine if you have a bad booster seal/diaphragm or whatever (I don't have this system, so I'm just guessing based on prior forum discussions. I'm sure the experts will sign in.
Jeepster
I would say its a problem with your brake servo (booster). I had huge loss of fluid some time back and it was leaking inside the servo. Servo was reconditioned and problem solved.
John Turney
I agree with TIm on both counts: fluid being drawn into the engine from the booster and you don't want brake fluid in your Depends.
RAC68
RAC68
Hi Guys,
Thanks for your inputs as was also on that path of thinking and the reason for my dismantling the booster. The booster had no brake fluid in the air piston chamber and the vacuum tube to the intake manifold was dry. I think it would be impossible for all the fluid to be sucked into the engine without some indication or residue in the booster or vacuum tube.
The booster is dry and clean so I guess that rules out the booster as both source and destination for the leak. This is the reason for my frustration and the new thread. Everything pointed to the fluid being held in the booster, but it wasn’t. What’s next.
Ray (64BJ8P1)
Patrick67BJ8
RAC68 said:
Hi Guys,
Ray (64BJ8P1)
I had a leak several years ago and it was the resevoir to master line causing the problem. The line had been rubbing inside the meatl clamp that holds it tight against the wheelwell. It was very hard to spot since my engine compartment was filthy! While doing my frameup I've been replacing most of the orginal brake, fuel and wire harness clamps with "adel" clamps used on aircraft.
RAC68
RAC68
Hi All,
Patrick, I have been checking the lines and, as yet, have not found any indication of the lost fluid. I intend to continue the search when I start to rebuild the wheel components and booster. Although everything I’ve touched seems in very good condition after 20+ years (I believe due to my use of silicon brake fluid), its time for a redo.
Derek, I checked the carpet in my search and found it dry. However, since I only checked the carpet’s surface, today I intend to pull it back and see if there is any fluid on the padding. I doubt I will find any fluid as the rubber caps on the clutch and brake masters was dry.
Last night I went through the system in my mind and put the search results down to review:
1. Strong solid brake peddle with no sinking.
2. No fluid on the surface of the driver side foot well below the M/C.
3. No fluid in the brake drums.
4. No fluid on any side of the front disks.
5. No fluid in the booster air chamber or vacuum line.
6. No fluid on any component connector.
7. After rebuilding the clutch slave, its reservoir section stayed at proper level.
And the search goes on. The thing that intrigues me is there was no sinking of the peddle when the brakes were applied. This seems to indicate to me that either the lost fluid was very small, easily compensated by the reservoir and at the less critical rear brakes or, as Patrick indicated, between the reservoir and master cylinder. My next target area is from the reservoir to the master cylinders.
Thanks for all the ideas and suggestions.
All the best,
Ray (64BJ8P1)
Johnny
I'm going to assume the brake and clutch pipes aren't reversed on the reservoir revealing only a problem with the brakes leaking somewhere correct?
If that's the case you might want to jack up the car and re-do a thorough check from front to rear of all the brake lines especially the lines at the rear of the car over the axles.
RAC68
RAC68
Johnny/Nevets, thanks for your assistance. I have dismantled the booster and found the air piston chamber and vacuum tube dry. Since I would expect at least some fluid residue in the chamber and on the walls of the vacuum tube, I don’t think the booster is my problem. However, I will be rebuilding the booster since I already have it dismantled.
As far as checking the other components, lines, and connectors, I will be rebuilding the calipers and rear wheel cylinders (along with the booster) and am checking every line and connector.
In a conversation with a good friend, multi LBC owner, and master mechanic, I was informed of something new to me. As previously mentioned, I have always had a solid and even brake peddle when applied. Well, he indicated that it was not uncommon for the master to leak when at rest and seal when applied. When applying the brake, pressure would expand the seal and eliminate any leakage. If the leak was small, you may never notice it by the paddle’s feel.
In modern disk/drum equipped cars, a pressure valve is incorporated in one of the external components (possibly the proportional valve) that keep a small amount of pressure on the system at all times to assure the seal is kept expanded. This valve is not in our LBCs and, therefore, we could experience this condition. Tomorrow, I am going to double check the rug and pad below the master cylinder to make sure my initial examination and conclusion was correct.
Thanks again,
Ray (64BJ8P1)
Keoke
check the carpet just below the cylinder on the firewall for leakage.
G Brake fluid missing Austin Healey 6
M MISSING BRAKE FLUID Jaguar 1
R brake master missing seal Austin Healey 11
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
F Missing and hesitation, only after a hot start Austin Healey 6
