General TR Where to get HVDA parts and vibration when engaging clutch.
Paulus
I recently developed a vibration when engaging the clutch on my 4A. Four years ago I installed the HVDA five speed Toyota conversion. In the event I need to replace any custom parts, such as clutch plate, does anyone know where to order HVDA replacements?
I tried an internet search as I knew of Herman’s passing and that the business was up for sale. I was wondering where people are getting their parts. If I have a pressure plate problem, that is easy as it is a stock TR6 item, my concern is that I may have some form of issue with the clutch plate or throw out bearing.
Check your instruction booklet. I believe all of the clutch parts are standard items; except for the hydraulic actuator which Herman told me can be rebuilt using commonly available O-rings.
ISTR the clutch friction plate is standard Toyota; pressure plate is standard TR4A. I can't recall offhand where the bearing itself came from, but it was a standard part.
Thanks, checked the book and found a part number for the throw bearing number but did not find a reference number for the clutch plate. I thought I remembered that the clutch plate was modified but I could be mistaken.
I hope that at some point someone starts to make the kits available again. Seemed like a great solution to the early TR overdrive issue.
David
�� Absolutely a great solution to the higher gear issue. For those of us that have them, at the least if between us we can identify part numbers and post them.
I found these two pages in my HDVA install booklet.This was for my TR6. Hope this helps.....
Arg.. I am typing all this a second time after it disappeared...
Not to further muddy the water, but I also have a HVDA in my TR3.
To not have a shake/shudder the proper bronz(?) bushing must be installed into the end of the crank -under the flywheel. The early cars (like mine) have a deeper recess machined into the crank than the newer ones. Most use a short bushing. The bushing must be a snug fit onto the transmission input shaft, and also fit snug into the crank. If you put a later bushing into an early crank, it will slide forward too far, and the input shaft will not reach the bushing -ask me how I know... The bushing keeps the input shaft centered into the center of the crank, and aids smooth operation of the clutch.
Also, Herman sourced his clutch discs from the best sources he knew. But on at least one occasion, the vendor subcontracted the manufacturing of the discs to a cheaper manufacturing facility. One thing that happened is the retainer that holds the springs was reduced from a rectangular hole with beveled sides, to simply a rectangular hole without the beveled sides. This resulted in a plate that worked, but over time, the springs dug into the non folded sides, eventuality cutting far enough that the springs were no longer retained in the hole, and caused complete clutch failure (ask me how I know).
The second set of parts I purchased from Herman were on 3/23/16. The disc was $105.00, the (tr6 style) pressure plate $130, the long input shaft bushing $14.00. I'm sorry but I don't have the generic part numbers or sources. I also cannot find my pictures of the failed clutch compared to the new clutch. Before you install your new disc, I highly recommend you make sure the springs are retained by FOLDS in the plate, and not simple holes cut.
I enjoyed speaking to Herman, and he really knew his stuff. I love the HVDA, even tho I have had a few problems. If I can help in any way, please tell me how.
Jer
Elliot,
This is probably what I need thanks for taking the time to find it and post it.
Paul
I have a complete HVDA kit for my 4A that I'm slowing working on here (sorry both are not for sale) and I went out to the shop to check the disc for you. It is in a box from clutchnet.com, the disc has an engraved clutchnet marking on it but no part # on the box or the disc. Clutchnet is USA company and I would suggest contacting them and they might be able to look up Herman's account and find their part # for us. I say "us" because please post what you find. Hope this helps.
edit: the disc I have has the folded metal over the springs as noted above.
So I contacted California clutch (clutchnet.com) and they say that they supplied the HVDA clutch disc. When I get five minutes I will follow up with a phone call and post what I learn.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
M TR2/3/3A Where does this screw go? Triumph 6
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
