where did my coolant go?
TomFromStLouis
I got the car out today in some 60 degree weather. Top down driving on new year's eve: gold star for me.
It sat unused for the past 4 or 5 weeks while the weather got well below freezing and the salt trucks did their thing. Rain cleaned the streets; I was raring to go. Not far from home I noticed the Temp gauge zooming past 212, well beyond the 230 mark. Pull into service station and I add ~3 quarts of water (first one $1.29, next two free). Problem solved; coolant (I use 50/50) was low. I will add a some 50/50 to top it off.
But I did not notice any under the parked car on my walk around. Any theories how and why this happened? Hoses look solid.
Johnny
It was the tornado Tom. It sucked the water right out of your radiator.
Sorry Tom, couldn't resist... We escaped the big one at my house.
Keoke
Well TomFromStLouis
If the tornado did not get it-- :laugh:
Then maybe you did not let the thermostat open when you first filled the radiator up.---Fwiw--Keoke
BlueRidge1
Tom,
Hopefully Keoke is correct, Another possibility is a cracked head allowing coolant to be expelled through the exhaust pipe. Have you noticed any steam coming from the exhaust? Another thing is to check the oil to see if any coolant is contaminating the oil from a possible cracked head or blown head gasket. If you do see signs of coolant in the oil do not run the engine as it will destroy the bearings.
Good luck
Bob
Deleted member 8987
And, if you added three quarts (3/4 of a gallon) of plain old H20, I for one would NOT be adding 50/50 a/f mix.
I'd be putting the real deal in.
Another thing....just buy straight anti-freeze, top off, when you get halfway down, fill with wather, felt mark the outside "50-50 mix", or, if you suse a lot, save an empty gallon a/f jug, buy a new one, pour 1/2 into the empty, fill both with H20, mark both.
You will most likely be amazed at how much cheaper two gallons of home mix 50-50 is compared to two gallons of store-bought pre-mix.
twas_brillig
we lost fluid last summer while car camping and I couldn't figure out where it was going every day until I noticed a wet track as we pulled in and parked at a view point - it was blowing out the rad cap while (whilst!) driving. Replaced the rad cap and no problem.
Doug
warwick-steve Where did the smell go? Austin Healey 11
R Where did it go? A who-done-it mystery! Austin Healey 18
Jim_Newman Where did I go wrong? Austin Healey 37
M where did it go Triumph 2
B TR2/3/3A Where did I see the picture of the TR3 bulkhead Triumph 6
M Where did my horn go?? Spridgets 4
KVH Where Did They All Go? Triumph 5
Stewart So where did you take your B today? MG 6
mgblue79 Where did the summer go? Spridgets 23
jlaird Where oh where did Jaybird go? MG 51
jsneddon TR2/3/3A Where did all my TR3 bottom end power go? Triumph 6
S T-Series Where did my clutch fluid go... MG 7
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
