It has been a long frustrating TR6 day - any help would be greatly appreciated. OK, another job I thought would be simple. I am changing over from wire wheels to solid wheels. The studs are longer for the steel wheels. I got my new studs from Moss. I knocked out the studs for the wire wheels. I have had to replace a stud from time to time in other cars and never had any problems. I would slip the stud through the back and pull it tight with the nut before putting on the wheel. It is not working on this car. Is there a special tool to do this job right? Any suggestions would greatly be appreciated. Thanks, Kevin
