TR4/4A TR4A Wheel Stud Removal
boeingpilot
I'm converting my '67 TR4A IRS from wires to Panasports, and have questions about the rear wheel studs. Are the studs on the IRS cars peened on the back? I read the thread on this forum, but couldn't understand if the IRS TR4A's are different from the solid axel TR4A's. I also understand the front studs are pressed in, is this correct? I would appreciate any info or tips before I dive into this. Thanx.
For the 4A IRS I believe they are all pressed in. You can check pretty quickly, just feel on the back of the hub, the pressed in stud has a pretty obvious shoulder, the threaded and peened in ones do not.
Interesting. The local British car shop sent me 4 press in type studs and 4 threaded studs. The tech guy at Moss said the threaded studs are for the back.
When I replaced a rear stud on my Spit I just tapped it with a mallet and it slid right out. I've tapped these as hard as I dare and they didn't budge. Sort of makes me wonder what those TR engineers were thinking.
My solid axle '4A uses pressed-in studs. Sounds like yours are just frozen. Try heating 'em. Hmmm, or maybe I'm thinking of my old TR6...
The 4A IRS setup originally was pressed in, but the live axle 4A I think had threaded just like the 3's and 4's. But again, I think its pretty simple to inspect the back of the hubs and you'll know exactly what you have.
It looks like these have been peened. Sounds like the idea now is to simply grind off the peening and back the stud out. Of course I'm leaving for a trip today so it will have to wait until next week.
No need to feel behind; the threaded-in studs also have a collar that can be seen on the face of the hub.
If you truly found a threaded-in stud on an IRS hub, I would consider replacing the entire hub. Triumph never built them that way, so someone has threaded the knurled hole. Those threads (and that bit of peening) are the only thing holding the wheel to the car; not a place for bodging, IMO.
I'll check some of my spare rear axles, but the part number for disk wheels (132317 - I got to use my new TR4A SPC!) is the same part number for TR4A IRS and TR6 rear axles according to TRF.
Scott
Any luck getting yours out?
I checked all 4 spare TR4A IRS rear axles that I have and they are all pressed in so if yours are peened then it sounds like someone replaced them at some point with the wrong kind.
Two of my spare axles already had the studs knocked out and you can see the knurls and beveled shoulder on the back. The other two axles still have the studs installed and I can say that the head is pretty thin.
Scott
They were, in fact pressed in all the way around. Crisis averted. Thanx for the info!
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
J TR4/4A TR4A rear wheel cylinder source Triumph 3
J TR4/4A TR4A Steering Wheel Triumph 3
G TR4/4A tr4a irs left rear wheel Triumph 14
C TR4/4A TR4A wheel cylinder install Triumph 4
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
F TR4/4A Knurl hole for TR4A wheel studs... Triumph 18
R TR4/4A Tr4a, wheel spacers and balance Triumph 5
R TR4/4A Tr4A, unidentified wire in steering wheel area Triumph 4
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
K TR4/4A TR3A wheel hubs and TR4A wheel hubs? Triumph 2
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
Stinger TR4/4A TR4A Rear Brake Wheel Cylinder Dust Shields Triumph 5
K TR4/4A TR4A Wheel Colour? Triumph 15
S TR4/4A TR4A Wheel studs Triumph 2
T TR4/4A TR4A - rear wheel steering. Whoa! Triumph 5
A TR4/4A TR4A picture of wheel arch needed Triumph 5
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
