TR4/4A TR4A Steering Wheel
jrvalente
I just installed a new Moto-Lita Steering wheel with a Springalex Boss. I am getting about 1/8 to 1/4 inch telescoping in the wheel now. Did I miss pulling something out or putting something in.
As I recall, there is a spacer / washer just behind the connection with the Allen head set screw which, if omitted, will introduce some slop.
I'll look for a pic.
Right about here I think...
You might watch that spot as someone works the steering wheel out & in -- see if that is where the gap is.
Are you sure you didn't have the play before you replaced the wheel? On a TR4, the lower donut mount by the steering rack is prone to slipping and can cause the telescoping you are seeing.
If there was no play before the change, you may need a washer between the thin nut that secures the wheel hub and the new hub. The nut bottoms out on the thread before it makes contact with the hub. I had this problem when installing a moto lita wheel a few years ago when the correct hubs were not available at the time...I have since purchased the correct hub and did not need the washer as a spacer.
R TR4/4A Tr4A, unidentified wire in steering wheel area Triumph 4
T TR4/4A TR4A - rear wheel steering. Whoa! Triumph 5
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
T TR4/4A TR4a steering shaft play Triumph 21
M TR4/4A tr4a steering colum bushing ??? Triumph 4
Stinger TR4/4A TR4A Steering Box Lubricant Triumph 6
T TR4/4A Fitting a sway bar to a TR4A & steering rack Triumph 5
bluemiata90 TR4/4A TR4A steering coupling warning Triumph 2
bluemiata90 TR4/4A TR4A HARD STEERING Triumph 2
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
