TR2/3/3A Valve Train Noise TR3A
mapleaf
I'm about to try and fix a noisy valve problem that has been annoying me since the head was redone in the late 90's. The unleaded gas conversion rebuild included new valves, tappets, hardened seats, guides, (3/2) valve springs, and a rocker arm reconditioning from RAS Calif. Pushrods were the only items reused. Probably should have replaced them too!!
Anyway, the engine has the normal tractor engine tappet ticking until it goes through the 2000 to 2300 rpm range then one of the ticks gets real loud. This happens whether powering up or backing off but only in that rpm range.
Just wondering if it could be a broken valve spring and how I would go about checking them out? Maybe a pushrod?
Any ideas, suggestions, tips, hints, whatever will be greatly appreciated.
TIA Barry
BTW living with it is still an option but hopefully not quite yet.
I suppose a start would be to rev it with the valve cover off and determine which valve is the offender. Could be a little messy but perhaps not too bad.
Since everyhing is new I'd wonder if one valve is sticking as it heats up.
If that's what has happened, maybe the push-rod for that valve may have become bent.
thechileman Valve train noise Triumph 11
D Valve train noise Triumph 14
G Valve Train Lubrication Austin Healey 1
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
C Ford pre-crossflow valve train Other British Cars 2
bertl TR2/3/3A TR3 Valve Train Pedestals Triumph 5
chrpark disassembling/cleaning valve rocker train Spridgets 5
T Valve Train Failure Triumph 30
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
E TR6 TR6 Valve Train Specs Triumph 0
jtb55 valve train oiling Austin Healey 2
M Valve Train Clearance Spridgets 14
78Z Lotus Engineering's Fully Variable Valve Train Lotus 8
J New healey 100 owner start up Q'S . Valve train Austin Healey 6
Y MGB Do I need a heater valve? MG 1
K TR2/3/3A Installing silicone valve cover gasket Triumph 6
BierRunner TR6 Thank You - Heater control Valve Replaced! Triumph 1
BierRunner TR6 Removing the old Heater Control Valve Triumph 2
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
K TR2/3/3A Valve rocker shaft questions..... Triumph 11
K TR2/3/3A Cylinder head valve stems and guides.... Triumph 3
BierRunner TR6 Heater Valve Triumph 20
Carlbanan56 MGB MGB valve seals MG 1
TomMull Valve lash Lotus 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 28
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
