TR2/3/3A TR3 Valve Train Pedestals
bertl
Member
Getting started to rebuild my TR3 engine and discovered the PO had damaged the pedestals on the valve train. I now find that they're NA in Moss catalog. Anyone know a USA source for replacements??
Thanks
TR3driver
Great Pumpkin - R.I.P
Used is probably your best bet. Ask again if Marv can't help you out for some odd reason.
S TR2/3/3A tr3 valve spring compressor Triumph 5
B TR4/4A TR3 valve cover on TR4A Triumph 4
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
JFeher TR2/3/3A Installing valve guide seals on 59 TR3 Triumph 6
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
J TR2/3/3A Tr3-eary 4s, draft tube and /or PCV valve?? Triumph 13
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
K TR2/3/3A TR3 Brake Proportioning Valve? Triumph 2
J TR2/3/3A Need original valve cover 58 TR3 Triumph 4
K TR2/3/3A Valve cover install TR3. Triumph 4
B TR2/3/3A TR3 brake restrictor valve Triumph 6
ekamm TR2/3/3A Tr3 heater valve Triumph 12
Twosheds TR2/3/3A TR3 Valve Cover Triumph 24
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
prb51 TR2/3/3A TR3 valve clearance settings Triumph 10
F TR2/3/3A TR3 "NonBreather" Alloy Valve Cover Triumph 3
M TR2/3/3A TR3 water valve Triumph 4
prb51 TR2/3/3A TR3 oil pressure relief valve Triumph 3
martx-5 TR2/3/3A TR3 Restrictor Valve Triumph 12
T TR2/3/3A TR3 pressure relief valve setting Triumph 6
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
K TR2/3/3A Valve gaps...fast road cam...TR3 Triumph 6
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
D TR2/3/3A TR3 Valve noise Triumph 4
mcguijo TR2/3/3A Cast Aluminum Valve Cover TR3 Triumph 5
mrv8q TR2/3/3A tr3 valve cover gasket Triumph 5
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
