TR2/3/3A TR3 oil pressure relief valve
prb51
I'm wondering if someone fiddled with the filter relief valve at some point or it's just cold and oil viscosity.
I live off of a highway a few miles down the road and even though I warm her up sometimes I have to get on it (dirt road leads to a two lane with 65 mph limit so folks are going 75) when a car crests the hill.
She'll climb past 70 psi some almost to 80 psi.
This only happens when the oil is still not warmed properly and I was wondering if the relief valve just can't handle the cold oil and rpm's or someone earlier messed with the set screw.
What do ya'll think?
After the oil is warm 70 seems to be the limit.
TR3driver
Great Pumpkin - R.I.P
The relief valve operates over a range of pressures, it doesn't instantly go wide open at 70 psi. So I'd say what you are describing is perfectly normal with a tight engine and fairly heavy oil.
I've pegged the gauge without apparent ill effect. (Back when I was using straight 40 weight instead of 20W50.)
tdskip
Oh man, this is the kind of "problem" that I'd love to have in my TR3.
Sounds like you did a great job when you did the bottom end work. Good going!
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
B TR2/3/3A normal oil pressure in TR3 Triumph 6
J TR2/3/3A TR3 oil pressure hose question Triumph 1
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
PatGalvin TR2/3/3A Target Oil Pressure for new TR3 Rebuild? Triumph 4
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
newmexTR3 TR2/3/3A TR3 Oil Pressure gauge issue Triumph 8
martx-5 TR2/3/3A TR3 Oil Pressure Gauge Triumph 3
T TR2/3/3A Once more with feeling, adjusting oil pressure TR3 Triumph 4
Tinkerman TR2/3/3A Oil Pressure Guage Line TR3 Triumph 3
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
S TR2/3/3A tr3 oil pressure Triumph 14
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
G TR2/3/3A TR3 Oil Strainer Repair Triumph 6
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
P TR2/3/3A TR3 Transmission oil Triumph 13
M TR2/3/3A TR3 oil filter cap needed Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
K TR3 Oil Temperature readings Racing 2
M TR2/3/3A TR3 aluminum oil pan Triumph 9
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
