TR2/3/3A TR3 oil pressure relief valve
rusty55
I've been watching my oil pressure closely since the rebuild. As stated in another thread, it sometimes drops to zero at idle. I ordered and installed a new oil pressure relief ball and spring. I turned the screw out 21 turns and re installed it 21 turns with the new ball and spring. Is there a better way to know where that adjusting screw should be set? My book says don't touch it, but its a little late for that.
R
rusty55
tdskip said:
Sorry to say this, but it is unlikely the relief value is going to fix much here.
That is likely true. However, I still need to adjust it to a point close to where it belongs.
TR3driver
Great Pumpkin - R.I.P
The relief valve is supposed to open around 70 psi.
R
rusty55
Thanks TR3driver, I figured before long you'd chime in and set me straight. I hooked in a oil pressure gauge that I know works and adjusted the valve. I think I'm good.
Thanks
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
B TR2/3/3A normal oil pressure in TR3 Triumph 6
J TR2/3/3A TR3 oil pressure hose question Triumph 1
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
PatGalvin TR2/3/3A Target Oil Pressure for new TR3 Rebuild? Triumph 4
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
newmexTR3 TR2/3/3A TR3 Oil Pressure gauge issue Triumph 8
martx-5 TR2/3/3A TR3 Oil Pressure Gauge Triumph 3
prb51 TR2/3/3A TR3 oil pressure relief valve Triumph 3
T TR2/3/3A Once more with feeling, adjusting oil pressure TR3 Triumph 4
Tinkerman TR2/3/3A Oil Pressure Guage Line TR3 Triumph 3
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
S TR2/3/3A tr3 oil pressure Triumph 14
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
G TR2/3/3A TR3 Oil Strainer Repair Triumph 6
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
P TR2/3/3A TR3 Transmission oil Triumph 13
M TR2/3/3A TR3 oil filter cap needed Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
K TR3 Oil Temperature readings Racing 2
M TR2/3/3A TR3 aluminum oil pan Triumph 9
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
