Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Is there an order for adjusting the valves? ie. when the 8th rocker is up adjust the one valve? Or should I just go from cylinder to cylinder following the fireing order?
Thanks..........
The magic number is 13. Subtract 8 from 13 and you set valve 5 when 8 is fully open(down position). If you loosen the plugs put it in 3rd gear (break off) and push forward they will come in an order checking and adjusting 1,9,2,5,10,12,6,4,11,8, and 3. This allows rolling forward doing valves in consecutive order.
Since your profile doesn't say what you drive and your ID is 'Blue MG' I will add that for a 4 cylinder engine the same process applies but the magic number is 9.
[ QUOTE ]
[/ QUOTE ]
Tahoe--
I knew about the magic number part but the order for rolling forward is new to me. Do you or anyone know the order for adjusting a four-cylinder car?
Ah.... So that's why it pings.
7 is right after 1 and before 9. Sorry. I found this in the Haynes shop manual and posted it in the garage. I lost the 7 running upstairs.
Michael, since no one responded I would just push forward and record the valves as they open for the next time. Or it is probably the same for all 4's (MGs sprites and others) with the same firing order.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
