    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TRactor Motor Valve Adjustment Sequence
MichaelG
Believe there is "improved" valve adjust sequence to the factory manual method for the 4 cylinder TR engine that requires much fewer turns of the engine. Can't seem to find it anywhere on line....what is the best sequence?, it been a while since I did this and I can't remember
Thanks
MichaelG
When I had a 64 TR4, turning the engine over was easy. I just used the hand crank (AKA as the non-Lucas starter) that went in through the front of the car. There were times I wish my TR6 had one.
But in my Haynes manual there is a misprint in that chart. Sorry don't have it handy to quote but one of the valves is listed twice and (of course) one is omitted.
Pretty easy to work out which is in error using the 'rule of nine'. May have been corrected in later versions.
How about setting the crank so #1 cylinder is at TDC, pointer aligned with the hole on the pulley, then adjust #1 intake and exhaust, #2 intake and #3 exhaust. Turn the crank one revolution so the pointer and hole again align and adjust #4 intake and exhaust, #3 intake and #2 exhaust.
Bob
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
martx-5 TRactor Motor Crank Breakage Triumph 19
CinneaghTR Who makes the best TRactor motor cooling hoses? Triumph 4
martx-5 Adjusting Valves on TRactor Motor Triumph 7
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
martx-5 TRactor Motor Rear Seal Triumph 7
michalotti_tr TRactor motor timing chain tensioner Triumph 7
Basil Ford Tractor Spotted 12
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
kennypinkerton Tractor Supply Blasting cabinet. Restoration & Tools 6
Rut Harbor Freight/Tractor Supply Spridgets 4
aeronca65t Fan powered tractor Spotted 2
J New lift tool for my garden tractor Restoration & Tools 0
Darrell_Walker The Unlikely Tractor Triumph 4
CinneaghTR TRactor Water Pump Pulley ID? Triumph 9
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
tony barnhill Tractor Supply Company..... Restoration & Tools 9
T Drunk lawn tractor driver Triumph 8
Tinkerman Oil in the TRactor engine? Triumph 2
TR3driver The Unlikely Tractor Triumph 25
YankeeTR Car shows, tractor pulls and a swap meet... Triumph 6
Tinkerman Threaded Hole in the Tractor Block? Triumph 9
H Fergeson tractor Other British Cars 4
Tinkerman Standing Proud on a Tractor Engine Triumph 1
Tinkerman Painted my tractor engine block Triumph 1
Steve_S Vintage Tractor Parts - Source? Other British Cars 8
Tinkerman Tractor engine assembly - BOY am I having fun! Triumph 7
S The Tractor Engine "Myth"??? Austin Healey 7
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
