    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
valve adjustment?
mtlman8
what is more common on the 67 tr4a... .012 or.015 i've heard both and can't find my manual, so I don't know what it says.
It's supposed to be .010 cold.
Scott
.010 is correct, however I set them at .012 -- the notion is to error on the side of having them a bit loose than risk getting one (esp and exhaust valve) too tight. Either way, they will probably make a bit of noise.
IMO, the .010" already has a bit of margin built into it; the engine will run fine at .008". So I set mine to .010".
Assuming you've got a stock camshaft, of course. Many aftermarket cams call for more clearance.
One thing to consider when you are setting the valve lash (I use 10. Cold) is that the tappets with wear become dished and when you place the feeler gauge in you bridge the dish in the tappet and get an untrue setting. This is usually a problem when you trying to get a noisy lifter quite. The danger is that people sometimes guess at what the setting is to allow for the dish and it up getting it too tight. So if that is what the problem is, the answer is to rebuild the rocker shaft. It is not that hard to do and will make a big difference in performance and noise.
Steve
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
K TR2/3/3A Valve Adjustment? Triumph 17
L TR6 Bypass valve adjustment Triumph 1
wangdango BJ8 valve adjustment? Austin Healey 3
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
Boggsy64 MGB Valve adjustment MG 6
Darwin GT6 GT6 Valve adjustment Triumph 6
nevets Valve adjustment intervals? Austin Healey 15
6 Valve adjustment stock 948 Spridgets 11
glemon Valve Adjustment/Wear Triumph 4
Rut 1275 valve adjustment Spridgets 10
Rut timing, cams, valve adjustment Spridgets 6
BOBBYR VALVE ADJUSTMENT Austin Healey 1
G MGB MGB valve adjustment MG 3
M 1275 valve lash adjustment "shade tree" Spridgets 10
Marvin Gruber Valve adjustment Part 2 Jaguar 11
Marvin Gruber Valve adjustment Jaguar 15
I Valve adjustment basics - help please Spridgets 21
I TR6 TR6 valve adjustment help Triumph 3
Woodie valve adjustment Spridgets 5
66healey Valve adjustment Austin Healey 11
newmexTR3 valve adjustment q's Triumph 4
T Valve adjustment 'how-to- on YouTube? Triumph 3
R Valve Adjustment Question Austin Healey 12
malice Valve Adjustment Triumph 2
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
H Valve adjustment question MG 10
M TRactor Motor Valve Adjustment Sequence Triumph 5
sparkydave How sensitive is the valve adjustment? Spridgets 11
B valve adjustment Austin Healey 7
R Valve adjustment Austin Healey 6
S Valve Clearance Adjustment Austin Healey 17
M Valve adjustment MG 12
J Valve adjustment help. Triumph 5
tahoe healey valve adjustment Austin Healey 14
BierRunner TR6 Heater Valve Triumph 13
Carlbanan56 MGB MGB valve seals MG 1
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
