Valve Adjustment Question
Ray7Smith
Just installed a rebuilt rocker on my BJ7. I need to know the best method of rotating the engine in order to adjust the valves.
Is using the starter motor to rotate the engine the best method?
Ray
mjobrien
Best method if yu can get a wrench or socket on the crank nut. Not always practical but it allows for the best control. Remove all the plugs to make it easy to rotate...
Michael.
55 BN1.
Dave Richards
Remote Starter Switch Less than $20 at NAPA.
OR...
The original Starter Solenoid had a start button on the back of it! Replace yours with an original.
From there it's pretty easy, touch the button to get the valve in the correct position, adjust it and do the next valve.
Patrick67BJ8
I remove the plugs and put the car in gear and gently rock it(move it) to exactly where I want lifter on the camsahft and adjust it that way.
I still prefer to use the E O I C method of valve adjustment over the "13" adjustment.
Patrick
Andy65
Push your hand down on the fan belt to tighten. Rotate fan blade by hand. Works best in one direction only.
Don't laugh - I can't be the only one who has done it this way for years.
steveg
With the plugs removed, I use a 15/16 wrench on the generator nut in combination with pressing down on the fan belt. I have a fan shroud and so cannot move the fan by hand.
I also use a paper timing disc inserted on the distributor rotor shaft in place of the rotor:
[img:left]https://www.pbase.com/stevegerow/image/84494410[/img]
This disc is divided into 60 degree pie slices and gives the proper order for adjusting the valves, starting with #1.
G
gblawson
I use the fan belt method as well...however, its on a 1250 4 cyl... Am setting the tappets this week on the 2.6 and will see if I can do it the same way?
bob hughes
I'm with Patrick - plugs out, roll the car.
Watch valves, when one is down the partner is up - gap it and look out for others on the way at the same time, with little movement you can grab a few of 'em almost at the same time.
Bob
Patrick67BJ8
Bob
Carefull Bob. Use the EOIC formula to be sure the adjustment is correct o and never hit it exactly. Otherwise you'll be readjusting. The EOIC formula will make sure you're are the right spot on the camshaft everytime.
Patrick
G
gblawson
What is the EOIC formula? (sorry, haven't heard that term before)
Dave Russell
Yoda - R.I.P
EOIC stands for exhaust open or opening/intake closed (adjust intake). There are several interpretations of just when/how much the exh valves should be open to do this. Some say exh. just starting to open, some exh fully open, some exh starting to close. I'll leave the when/how much to Patrick. It's usually done on long duration and or hydraulic lifter cams with long opening & closing ramps.
Patrick67BJ8
Here's the formula:
Adjust intake valve when exhaust just starts to open,
Adjust exhaust valve when intake is closing.(almost closed)
This formula was given to me by a machine shop in JAX Florida when I lived there and overhauled several Healey engines. He was a very experienced machinest and was able to repair any thing I threw at him with Healey engines.
Patrick
glemon
I always just put it in gear and roll it, plugs out, 4th gear (don't know if anyone mentioned that) I have never had good luck trying to do it by flipping the starter on and off, but your mileage may vary.
H Valve adjustment question MG 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
G Valve adjustment and easiest way set cam position Austin Healey 15
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
K TR2/3/3A Valve Adjustment? Triumph 17
L TR6 Bypass valve adjustment Triumph 1
wangdango BJ8 valve adjustment? Austin Healey 3
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
Boggsy64 MGB Valve adjustment MG 6
Darwin GT6 GT6 Valve adjustment Triumph 6
nevets Valve adjustment intervals? Austin Healey 15
6 Valve adjustment stock 948 Spridgets 11
glemon Valve Adjustment/Wear Triumph 4
Rut 1275 valve adjustment Spridgets 10
Rut timing, cams, valve adjustment Spridgets 6
BOBBYR VALVE ADJUSTMENT Austin Healey 1
G MGB MGB valve adjustment MG 3
M 1275 valve lash adjustment "shade tree" Spridgets 10
Marvin Gruber Valve adjustment Part 2 Jaguar 11
Marvin Gruber Valve adjustment Jaguar 15
I Valve adjustment basics - help please Spridgets 21
M valve adjustment? Triumph 5
I TR6 TR6 valve adjustment help Triumph 3
Woodie valve adjustment Spridgets 5
66healey Valve adjustment Austin Healey 11
newmexTR3 valve adjustment q's Triumph 4
T Valve adjustment 'how-to- on YouTube? Triumph 3
malice Valve Adjustment Triumph 2
TRclassic3 TR2/3/3A TR3 Valve Adjustment Triumph 10
M TRactor Motor Valve Adjustment Sequence Triumph 5
sparkydave How sensitive is the valve adjustment? Spridgets 11
B valve adjustment Austin Healey 7
R Valve adjustment Austin Healey 6
S Valve Clearance Adjustment Austin Healey 17
M Valve adjustment MG 12
J Valve adjustment help. Triumph 5
tahoe healey valve adjustment Austin Healey 14
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
