Tri-Carb Project
Healey Nut
Healey Nut
Are you using Pertronix?
No points or condenser. I have a Lumenition kit on order, but won’t get that until I go to the UK in September.
Well, check your dwell. An overheating coil can be caused by too much dwell, but your coil could be defective. I heard Lucas 'sports coils' had issues a while back.
Healey Nut
Healey Nut
Parts arrived at my friends place in the UK .
Electronic ignition to be installed on my return to Canada later this year .
mezy
The old school way of setting the timing is to do it on the road, advancing the timing slowly till it starts pinking,
then back the dizzy off until the pinking stops, not all engines work best at the manufacturers settings,
This is how modern engines work now, the ECU is constantly advancing ignition timing until the knock sensor detects pinking
then backs the timing off, then starts to increase the timing again,
Healey Nut
Healey Nut
So I’ve been on a few local trips; nothing too far, just getting used to driving a side shift and getting more confident with the car.
I was at a small local car show and got chatting with a keen photographer guy who was using a 70s box-type camera with real film in it who was taking pics of my car. He also develops them himself. Here’s a couple that he sent me. They are B&W but quite striking.
Healey Nut
Healey Nut
The fix for the running issue was a carburation problem , it’s solved now , car runs well but has a gearbox issue which means I think the gearbox is coming out over the winter . If you’re cruising at say 60mph and have your hand resting on the gearshift . When you take your foot off the gas you can feel the rear axle unwind as the speed drops and if you don’t hold down slightly on the shifter it kicks out of gear .
I only did a visual on the gearbox when I restored the car it all looked good inside . Now I’m thinking the interlocks for the gears are either worn out or the interlock balls are not in place .
It sounds fine you just have to keep a hand on the gearshift with gentle pressure when you decelerate .
Winter job for me .
HealeyPassion
Winter job for me .
I'm jealous that you are at the obligatory debugging stage.... IMHO an unavoidable stage in all nut/bolt rebuilds. I hope to be at this time next year!
Much to do ... off to the shop!! Steve
Winter job for me .
Healey Nut
Healey Nut
Another couple of the B&W pics sent to me by the same photographer as the previously posted ones .
Healey Nut
Healey Nut
Still tweaking timing and carbs but getting close to running as I want . Going to live with the gearbox issue till off season .
The car does get well admired at car shows .
Im getting better at taking pics of it too .Pity I cut off the rear bit of the fender on this one .
Healey Nut
Healey Nut
Look what arrived in the mail today . Four page article inside on her journey from the scrap yard gate to how she is today .
Thats a lot of scraped knuckles and dirty fingernails there .
I wonder what the original owner would think ?
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
