Tri-carb help
kindanice
I have tried all over the world for a part without success hence is any member able to supply dimensions/angles so I can manufacture an accelerator spindle (the bit that fits into the firewall and links to the throttle shaft. See Moss catalogue Item 60 on Tri-carb engine controls BN7,BT7 page.
If no one comes up with these dimensions before then, I'll shoot some pictures and make some measurements on mine this weekend.
Thankyou Guys. The required bit is not in any of the usual suppliers however I have sent them emails hoping they may have one stashed away.
Keith - Any pics/info will be very much appreciated.
Kind regards...Lyall
Lyall,
I have uploaded a few pictures here:
https://picasaweb.google.com/100928264363269111754/TricarbThrottleShaft
It's not an easy part to get pictures of while it's in the car, but I did my best. The overall length of the shaft is almost exactly 9 inches. The bit that turns up at the end furthest from the firewall is about 1.5 inches. As you can see, that part could be a little longer and not hurt much. The connecting rod that goes down to the accelerator shaft is about 6 inches long. That part you will probably want to find from the SU people because it has ball joints on the ends.
The hardest part, I think, will be the piece that attaches the shaft to that connecting rod. The angle between that and the bend at the other end has to be pretty close if everything is work right. Of course if the downward shaft was slightly longer or shorter than 6 inches, the angle would have to be different.
Hope this helps.
Lyall,
I have an original one that I cadmium plated with the rest of my nuts and bolts. Let me know if you're interested.
Duane
'58 BN6
Keith,
Thanks for your efforts. Unfortunately I can't open the file. Don't believe I'm doing anything wrong?? I get the message "Sorry that page not found" although the tab acknowledges Picasso web album Keith Mott??
Duane,
Yes, very interested. How much would you be asking for it?
Thanks fellas
Lyall
Lyall,
you should be able to open it now. However, I would buy the one from Duane if the price is reasonable. Making one sounds tough!
Thanks Keith,
Pics are perfect. If I don't have any success with Duane I am sure I can manufacture one.
Once again thanks for your trouble.
Cheers Lyall
Hi Duane,
Thanks. Read PM and replied.
Cheers Lyall
Thanks to all. Duane able to supply my needs.
Lyall
K Tri-carb help please Austin Healey 0
J Seeking tri carb help Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
Healey Nut Tri-Carb Project Austin Healey 213
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
