TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs
JohnnyMead
I know the fuel line goes straight up from the fuel pump then bends 90 degrees, but how does it get around the water heater piping? Does it go between the pipe and the block or does it bend around the outside of the pipe?
Thanks,
John
Don Elliott
The fuel pipe bends around and under the front of the thermostat housing. My 1958 TR3A is an early car with banjo fittings to the carbs from this point near the housing shown. Later TR3As after about TS43000 have rubber slide-on fuel hoses to the heads of the float bowls. If you have rubber hoses to the carbs, secure the rubber hoses to the fittings with tiny clips used for fuel injection hoses and pipes on modern cars. These later TR3As and TR3Bs may also have a different attachment device under the nut on the front of the thermostat housing.
TR3driver
Great Pumpkin - R.I.P
I believe the heater line should be between the fuel line and the block. This shot from Practical Hints isn't totally clear, but I believe that is what it shows, and that is what I've found on a majority of cars.
JohnnyMead
JohnnyMead
Thanks everybody. Helpful pictures. However I route it I will need to practice my tube bending - that first bent out of the fuel pump looks tight.
John
TR3driver
6TTR3A
I routed mine in front of the thermostat housing like the
various illustrations indicated but had problems with vapor lock.
After a short stop on a So. California hot day it refused to
start unless I temporarily disconnected the fuel line. After
some experimenting I rerouted the fuel line as shown & my
vapor lock went away. Not correct but in my case practical.
Frank
CJD
Johnny,
I got my new line from Moss. I have benders, but did not need them because the metal was so soft. If you look at the pic, it took some pretty tight bends without a hint of caving. In fact, the metal is so soft I ruined it by overtightening the pump fitting...had to get a second line!
Also, glad you started this thread...I'm gonna move mine back outside the heater line...
John
Geo Hahn
Mine, more or less following the book though perhaps I should have the rise from the pump more vertical.
And a detail of the cap tube attachment. I used friction tape (hockey stick tape in the NE) under those aluminum strap thingies:
JohnnyMead
JohnnyMead
Wow, nice pictures everybody!
John: I'm thinking about using that softer tubing as well. I used it at the fuel tank end with good results. The one I got from Moss came with the correct shaped ferule.
sp53
So Don I know you have an original car and that is the way the early Banjo fitting cars hung the fuel line? They used a clip around the fuel line and hung that from the thermostat housing bolt and did not use the rubber two line grommet thingy with the hanger?
Steve
TR3driver
I don't believe the rubber grommet thing came in until long after the banjo line was gone. None of my TRs has had the rubber thing, but most have used push-on fittings to the carbs.
The rubber grommet (133083) and clip (133072) aren't even listed in the TR3 SPC.
sp53
Thanks Randall for your research, much appreciated. Years ago Barry N. told me that when he sold me some original fuel line for my banjo system and I did not believe him. The fuel line he sold me had that round brass eyelet hanger and I thought it was homemade or something. I deduced that from looking at the Moss catalogue and put the rubber thingy in, now I am going out to the barn and see if I can find it.
Steve
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
Tinkerman TR2/3/3A TR3A Temperature gauge capilliary tube routing. Triumph 0
Tinkerman TR2/3/3A TR3A Temp Gauge Sensor Tube Routing Triumph 2
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
