Could anyone identify the "condenser" type item at the right of my voltage regulator?
One black lead appears to run into (or under) the regulator. The other black lead is capped off. No clue what it's for.
There's no evidence of the car ever having a radio, and the "condenser" looks to have been mounted a long time ago.
Also, there's no ballast resistor anywhere in the coil circuit. It's a Lucas standard coil.
Should there be a resistor somewhere in that circuit?
Is the "mystery" item an old ignition circuit resistor of some kind?
Thanks.
Tom
Thanks.
Tom
