TR2/3/3A TR3A Plug Gap?
karls59tr
Bronze
What is the prefered spark plug gap .025 or .032 ? I'm going to run the NGK BPR5HS (a little hotter than the BPR6 to see if it will cut down on the carbon fouling). I have 87 mm pistons,Pertronix ignition,mild street cam and a header. Doing the Spring tune up today. :smile:
If it's really carbon rather than oil, then IMO you have a mixture problem rather than a heat range problem.
I run .025" as per the book. Tried .032" (along with a MSD 6) but it didn't seem to help at all; and IMO the higher voltage allowed by the larger gap makes the cap & rotor more likely to fail.
Get the mixture straightened out. The fives are a cover up, in a worst case, potentially a costly one.
Well actually I rebuilt a set of SU's over the winter that I will be installing soon so I appreciate what your saying about the carbs and mixture. I think what was actually happening was the mixtrue nut was stuck to the lower jet bearing on one or possibly both carbs so I wasn't able to do proper adjustments. The rebuilt SU's should take care of that problem. I'll probably leave the NGK 6's in untill I have the carbs installed. I was just wondering what other "3" owners were running for plug gap?
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
B TR2/3/3A TR3A Oil Gallery plug Triumph 6
Got_All_4 TR2/3/3A TR3A Spark Plug Wires Any Good Ones Out There? Triumph 11
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 0
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 17
C TR2/3/3A TR3A Electrical problem Triumph 20
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
