TR2/3/3A Tr3:installing a speedi sleeve timing chain cover?
karls59tr
Bronze
I'm getting a lot of oil thrown up on to the front of the engine to the point where the fan belt is getting coated and there is more than the usual amount of oil on the driveway. I have recently replaced the pan gasket as I originally thought I had an issue there. I'm pretty sure the timing cover seal is the culprit and I see Moss has a speedi sleeve kit. i'm assuming I pull the apron(have to do that anyway to fix a gaps at the hood/fender/apron),pull the rad, fan and timing cover to gain access to do the install. What is the procedure to install the speedi sleeve at this point? Anyone done this with the engine in situ? Karl
mallard
I got my sleeve from www.rockauto.com part #99174 redi sleeve $23.95, which a lower price than you know who. I put mine on with the engine on the stand so I can't help with your installation question. It does come with the tool to tap it on though.
TR4nut
Yep, did the same thing as Keith for sourcing it, though I saved a few cents by buying the Timken version: KWK99174 for $21.79 :laugh:
Procedure is pretty much as you have it - but the timing cover is only pulled to replace its seal, a must do in this case I think but not needed for the speedi-sleeve install. It will just tap on with the tool that comes with the sleeve, then there is a little fiddling to tear off the install part of the sleeve - it is slightly scored so will come off, kind of like opening an old style tuna can.
TR3driver
Great Pumpkin - R.I.P
Or just leave it in place. It doesn't hurt anything.
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
jfarris TR2/3/3A Installing replica Brooklands Areoscreens on early TR3 Triumph 4
JFeher TR2/3/3A Installing valve guide seals on 59 TR3 Triumph 6
Lukens TR2/3/3A Installing pusher fan in TR3 Triumph 13
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
K TR2/3/3A Installing Brake Switch TR3? Triumph 6
af3683 TR2/3/3A Installing TR3 Millboard Gas Tank Cover Panel Triumph 5
M TR2/3/3A Installing new gasket on TR3 differential cover Triumph 13
S TR2/3/3A installing wiring harness tr3 Triumph 6
H TR2/3/3A TR3- installing gas tank = nightmare Triumph 18
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
martx-5 TR2/3/3A Installing Tonneau Cover - TR3 Triumph 6
martx-5 TR2/3/3A Installing PCV system on TR3 Triumph 5
Tinkerman TR2/3/3A Installing Piston Liners 60 TR3 Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
