TR2/3/3A Installing front fenders on TR3 from TRF
Bruce100
Hi all,
Trying to install replacement front fenders on a TR3B from The Roadster Factory. It seems to me that in order to get the fender in, it has to slide in from the side (towards the center of the car) rather than front to rear. In order to accomplish this it seems you have to trim about 4" of the inner vertical lip of the rear channel so it can slide in the gap sideways. I'll take pictures later, but thought someone would be very familiar with this and be able to verify.
thx.
TFB
My post 60k fender channel starts 6" from the rear of the top of fender.
I slide the fener to th rear,the little vertical lip going through a small notch in bulkhead.Then lift up fender while you guide the vertical mounting flange over the mounting plate on body.
interested how the rest fits for you.
tom
TomMull
tom
Yes but the channel end has a fold that often does not like to go under the scuttle at the point where the inner wing is welded to the firewall. Mine needs a lot of tweaking on one side to get that lip in, after that it slides right back.
I'd also be interested in the rest. I've heard rumors about the aftermarket fenders but have never seen them.
Tinkerman
Mornin, Do you have all the wires in and hooked up?
Tinkerman
B
Bruce100
It goes under the scuttle fine. I cant slide it all the way in because it runs into the vertical flange and I cant get it up and over
bgbassplyr
I'm in Charlotte and willing to give and extra hand if you need one. PM me if I can help.
TFB
Mine also hits that flange when sliding the fender to the rear.thats when I lift the bottom of fender up until your other hand feels the the fender mounting flange go over the body mount.It has to lift to about 60 +
degrees on mine.
Tom
Kleykamp
Yep. That's how I remember it. Acutally I think you slide the lip under the edge of the scuttle while holding the bottom out as mentioned, then you can slide it back and forth to mate up to the flange.
TexasKnucklehead
So how do they fit?
Here's a picture of what I think is the pivotal point of the installation. After you find this point, it falls together.
B
Bruce100
I'll take a picture tomorrow. there are some funky gaps along the top. along the doors looks good. I hate to think what it is going to be like installing these painted!!!!!
drooartz Installing front hubs, tips? Spridgets 15
aero3113 Installing Front rotors to hubs Austin Healey 2
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
J TR2/3/3A Having fun installing the front bumper and bumperetes Triumph 7
bighealeysource Installing front fender stainless steel beading Austin Healey 4
drooartz Installing front suspension/brakes - review Spridgets 1
H Installing New Front Wheel Cylinders Austin Healey 12
T Installing front anti-rollbar poly bushings Triumph 4
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
