TR2/3/3A Tr3 headlight buckets
sp53
Tr3 headlight buckets. I was looking to switch out a pigtail for the headlight buckets and was wondering about a good way to get the old one out in one piece. I removed some once, but not so easy now. I do see they sell new ones, but I am not sure on the quality.
Plus, I would like to repair one of those brass caged barrel nuts that hold the adjusting spring if anyone has a good idea; they look crimped in and not moveable. Or perhaps purchase a whole new set up if the quality is not too bad.
CJD
The wiring harness is just a rubber plug that pops in or out. Of course if it is old there may not be much flex to the rubber anymore. I'm trying to remember the crimped nuts. It seems like I was able to pry the crimps to remove them and then crimp them back...but that's been 3 years, so my memory fails. I just looked through my pictures without luck.
S
sp53
yeh that rubber has gotten supper stiff. I did get one out but my hands are not as strong as they used to be, I might need to cut the other. John did you buy new or use the old, and if so did you take the plug end apart for cleaning.
steve
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
5 TR2/3/3A Headlight trim removal on TR3? Triumph 3
NutmegCT TR2/3/3A Headlight trim ring TR3 Triumph 6
Skip_Shervington TR2/3/3A TR3 Headlight Relay Installation Triumph 9
R TR2/3/3A How do I install the headlight rings on a TR3 ??? Triumph 8
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
martx-5 TR2/3/3A TR3 Headlight Assembly Triumph 2
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
