Hello Webb,
"6 Speed, if cost efficient, would be even better."
Sorry, I have to disagree, unless you like changing gear for the fun of it. The Triumph has high torque and does not need a multiple gear set up. Personally I prefer the standard Triumph 4 speed and overdrive, which gives relaxed cruising in O\D fourth and a great overtaking range (about 50 to 100 mph) using third and overdrive third (almost instantaneous upshift with your foot hard on the throttle). No five or six speed can match it.
Alec
