TR2/3/3A TR-3B carburator issues
K
Ken H
I'm pretty sure you're correct because it's the richer needle (about 8 percent more flow area most of the time). This makes sense because the 2138 cc engine is that much larger. Thanks for your input. I'll stick with the SMs for now while I look for other reasons the car is misfiring. Thanks.
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
AngliaGT MGB-GT SU Carburator Linkage - MG 9
glemon Carburator Contentment Ahhh! Triumph 1
J TR2/3/3A carburator decisions for TR3A Triumph 48
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bcbug Replacing carburator on Midget Spridgets 16
J Carburator draining Triumph 3
R carburator issue Triumph 1
J Zenith Stromburg 175 carburator tune? Other British Cars 3
P Cleaning carburator air filters Austin Healey 2
S Backfire through rear carburator Austin Healey 18
R Gas leaking from the carburator - help Triumph 8
T Gas running from carburator tube?? MG 1
Deanrobert Xke series lll cooling issues Jaguar 5
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
drustom fueling issues Restoration & Tools 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
Celtic 77 MGB 77 Stromberg issues MG 12
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Celtic 77 MOSS response issues Restoration & Tools 11
A Spitfire Spitfire Fuel pump issues Triumph 5
Celtic 77 MGB 1977 MGB Brake issues MG 8
I Bugeye charging issues Spridgets 8
T TR6 Continuous Starting and Ignition Issues Triumph 6
E MGB MG Idle issues, restart issues solved. MG 4
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
J Wiring Harnesses Issues Spridgets 3
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A TR3A electrical issues Triumph 2
R TR6 1973 Final drive issues Triumph 5
G 79 Midget Clutch issues Spridgets 9
Dnickels Spitfire Spitfire lighting issues Triumph 4
I TR6 Dash light issues Triumph 19
Rob Dodge Trafficator arm issues. Jaguar 2
M 1972 Midget Engine Issues Spridgets 10
R TR6 Gearbox rebuild issues Triumph 8
A Front wheel bearing issues Austin Healey 11
T 100-6 start up issues Austin Healey 6
N Electrical Issues Need Help Austin Healey 8
sundown TR6 Fuel issues Triumph 5
R TR6 Clutch issues Triumph 7
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
N TR6 Electrical Issues Triumph 5
FlyingCat Spitfire Clutch Issues Triumph 8
F TR6 Carburetor issues at low rpms webers Triumph 23
