MGB MG Idle issues, restart issues solved.
Eleven22
This is my first post here, but I have been tackling an issue with my 78MGB that drove me crazy. I finally figured it out and got it running , but let me explain what was occurring just in case it helps one of you in the future.
I could start my car and when it was cold it would run like a champ. If I drove it around 'til it warmed up and stopped somewhere, on restart it would stumble and eventually die. It would also stumble to die when I took it on a long drive and came to a stop. I was having to hold the pedal down to keep it from turning off, just to get it home. I It would cool down again and all was well. I ended up using the shotgun approach and replaced the EGR valve, the run on valve, the gulf valve, filters, sparks, cap , rotor and wire set. still same thing...
I took it to Steel Automotive (British car experts) here in Austin TX and they did the timing , valve adjustments, and looked over the carb. They set all to spec I came to pick it up thinking everything was good. After driving it a good 15-20 min in traffic , it started stumbling. Took it home looked it over, called them up, they suggested the distributor or ignition system had to be off somewhere.
I decided to replace all my vacuum hoses and evap hoses and it seemed to make a diff, I could now drive come to a stop and all seemed well. then i drove it to a friends house and left about 15 min latter. As soon as I started it, it chugged and died. So I did my limp back to my house to start the chalkboard drawings.
I sat thinking about it , and I felt that the evap cannisters had to be the issue. it ran fine as cold, ran fine as hot unless I turned it off waited a few min and tried to restart. Today I took the cans out and rebuilt them with new charcoal, the old filters were destroyed and they were definitely in bad shape. After rebuilding them and driving around til it was hot, I parked it , and sure enough it started and idled! it idles a little low but it doesn't die. and once I start to drive again , all is well when I come to a stop.
Hope this helps someone out there, and thanks for allowing me to join the group!
JPSmit
thanks for the input - I suspect most of our cars don't have the evap containers any longer, making this even more helpful as most of us wouldn't think of checking there. :cheers:
E
Eleven22
My MGB is almost 100% stock , no changes. haven't lowered it , I still have the smog system on it. But I will say I am definitely pondering making it 5 speed or adding OD to it. the HWYS suck with this and I could use some cruising speed with low RPMs
drooartz
I have OD on my MGB, and clicking into that high gear is a lovely thing. I've driven one with a 5-speed conversion as well and it was quite nice. Worth doing for sure.
Bob Branson
Member
Worked at the dealer when your '68 was built, and those cars all seemed to have the same problem, so much so that Leyland sent someone to try to sort it out. I don't recall what the fix was, just that that it was maddening. I've always wondered, since this was right after Leyland bought MG, if they weren't just trying to kill Triumph's competition ;-))
M Idle Issues Triumph 1
jmayled TR6 TR6 - Idle Issues Triumph 5
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
crispy Idle Speed Variation Austin Healey 19
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S Can’t get idle speed below 1300 RPM Austin Healey 28
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
NutmegCT T-Series MG TD idle speed? MG 12
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
wkilleffer MGB Air leaks and fast idle speed MG 11
Marla TR4/4A Idle spring? Triumph 7
D 69 E Type High Idle Jaguar 9
K TR2/3/3A Mild street cam and Idle? Triumph 13
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
J MGB Project car done: idle variable MG 2
J SU HD6 - Slow Idle Screw Austin Healey 13
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
S Idle falls until car stalls Austin Healey 10
steveg HD8 high idle aggravation Austin Healey 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
Geo Hahn TR4/4A Stumble Off Idle When Hot Triumph 4
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
