T-Series MG TD idle speed?
NutmegCT
I've looked through my workshop manual and owner's manual. Can't find the speed to adjust the carbs for warm idle.
Other than "lower the idle speed until the dynamo light begins to flicker on", does anyone know what speed was expected when new?
Thanks.
Tom M.
Mickey Richaud
Fairly low, as I recall - 500-600 rpm maybe.
Platinum
:iagree:
That's why they call it "tickover".
PAUL161
Correction, Mine is set at 900 rpm, not 850, it will idle much slower but I like it at 900, my generator comes in at 1000, could re set it but it's fine. When all works well, I leave it alone. My plugs are color tuned and all are registering the same color. PJ
Made a mistake sorry, my idle is set at 900 rpms, just checked.
NutmegCT
NutmegCT
Thanks gents. Here's what I just found in the 1986 edition of the New England T Register's "T Series Handbook" (articles from The Sacred Octagon):
p. 128 Common Problems. "You may find it impossible to show the idling speed down to the recommended 700-800 rpm range."
TM
pdplot
As I told you in my article, it may change with the temperature outside - or it may not. 850 sounds good - if it will idle at that.
Mickey Richaud
NutmegCT
NutmegCT
Thanks Mickey. Never knew of BugGods before. Also interesting, he refers to the TD having one inch carbs, but most references say 1 1/4" and 1 1/2".
Ask three TD guys a question and get six answers?
Mickey Richaud
I've heard/seen the 500-600 rpm reference before, but a brief internet search didn't turn up much. Even the online shop manual is silent on an rpm value. ( https://www.ttalk.info/MG-TD-TF-WM.pdf ) Guess it's whatever floats your boat. I would think best practice would be about as low as you could get it and still have the generator charging.
Platinum
Or the gen light flickering.
NutmegCT
NutmegCT
Thanks gents. I'll have some time to play with the idle on Saturday. Six inches of snow in the forecast.
Doc ... don't say a word ...
Platinum
:devilgrin:
meh. I remember "snow".
Actually, I'll be in Miami tomorrow.
It's gonna rain.
Temperature is forecast to be a chilly 77* F as the high, will dip below 50* as a low.
I'll be miserable as a result, so take heart. :smirk:
crispy Idle Speed Variation Austin Healey 19
S Can’t get idle speed below 1300 RPM Austin Healey 28
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
wkilleffer MGB Air leaks and fast idle speed MG 11
S Idle Speed Setting versus Generator Output Spridgets 3
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
Anthony_S TR2/3/3A TR3a correct engine idle speed Triumph 8
M Adjusting idle speed Triumph 28
C TR6 69 TR6 idle speed continued... Triumph 2
C TR6 TR6 Idle Speed Triumph 5
ekamm Increasing Idle speed Triumph 4
R BJ8 + Novice. Idle speed adjustment help req'd. Austin Healey 5
B Idle speed for dynamic timing Spridgets 3
R Idle Speed Austin Healey 5
AUSMHLY idle speed Austin Healey 8
BoneIdle Idle Speed Drops After Fuel Filter Element Change MG 1
MadRiver Idle speed Triumph 7
Harry_Ward TR2/3/3A TR3 idle speed drop Triumph 7
wkilleffer Idle speed and engine temps MG 6
wkilleffer Vacuum advance and idle speed MG 11
D 1991 xjs v12 high idle speed. Jaguar 8
AltaKnight Idle speed adjustment Triumph 6
T Idle speed question Jaguar 2
S Correlation between Idle speed and timing Triumph 5
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
