I'm helping some friends get a MG TC back on the road. It's a beautiful restoration, but there are some mechanical things we're trying to sort out.
The car fired up yesterday, but we could not get the idle down below 2000 RPM. We did a quick check of the butterflies and they seem to be seating properly in the bores (we didn't pull the carbs, just looked in from the front). Idle screws are all the way out. We were struggling with the mixture. We ran the jets all the way up but they didn't seem to go far enough -- were not level with the bridge in the carb bore even with the nuts all the way up. The number on the needle was a 158.
The fellow I'm working with has a bunch of TC experience, I have none but have played with SUs for a number of years. We've wondered if the jets are incorrect, or are not correctly installed.
Looking for some suggestions on other things to try or to consider. No one involved did the actual restoration, so we're a bit blind as to what is in there.
