Should I get cloth top or vinyl - & why?
RickB
I see two main camps out there when looking for a new top, cloth or vinyl.
Are the cloth tops superior in any way?
I saw one on a B not too long ago and liked the way it looked.
I've always thought the cloth tops look so much better than vinyl. I don't know if one is better than the other though.
If the vinyl one has the zipper window in the back but the cloth one does not, does that sway opinion?
I'm asking because Franks top is shot & he needs a new one.
It will be several months before I can install it, but I'd like to get the research part out of the way.
Are either easier to install, or both about the same?
lbcarco.com sells Don Trimmings tops. I've heard many people say good things about them. I think they have a canvas top with a zipout window.
Yes they do.
Though $500 is more than I'm willing to spend on this car.
Is the top gonna stay up or down? If down, why spend the extra money for cloth when you could use that cash on something else?
This is the Northwest we are talking about.
Even though a day may start out as "top down" there isn't any guarantee it will stay that way.
Is the cloth top nicer when up? That's the feeling I am getting.
well, which top dries faster, cloth or vinyl?
& what happens when you put a wet cloth top down?
I assume the vinyl top dries faster.
So it would take a bit longer to dry out so it could be put down, but if its raining here and then suddenly clears up it's usually a while before its warm enough to drive with it down.
We don't get that 'warm rain' thing like you folks down south.
If it rains here, its cold.
(if you consider 50F - 60F cold) /bcforum/images/%%GRAEMLIN_URL%%/crazyeyes.gif
RickB said:
Yes they do.
Think that alone answers your question - what you need is a good Robbins vinyl top!
I've asked a few places for samples of their material.
I'll see for myself before ordering anything.
Here are two places I'm looking:
TopsOnline
and
EZ Soft Tops
I had seen those same two vendors... and was thinking of going with "TopsOnline". My '78 has (had) a 'cloth' (synthetic canvas?) top, and I much prefer the look of it to the pretend-leather finish.
Now if only a pine cone hadn't dropped off the 100' tree above the driveway, and gone straight through the old top... /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
It’s just personal taste, but I think cloth is better in every way.
Now that I’ve gotten a cloth top I can’t ever imagine buying another vinyl top. And I never even put the top up. The cloth is just soooooo much nicer.
I replaced my vinyl tonneau cover with a cloth one too.
PC.
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
