Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic?
60TR3A
Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? I'm entering her into a concours in September and I don't want to add an incorrect cap if what I have already is correct. My car has the black plastic of the later cars but if it is supposed to have the brass, I can order them and replace the caps. Any and all help will be most appreciated.
DerekJ
They are HS6 carbs and came with Black plastic caps. Brass look better and are available. Not sure what kind of Concours it is but unless its being run by the Healey Concours Registry I doubt the judges will know the difference.
bighealeysource
Bronze
Per the Healey Concours guidelines : "up to and including early 29D series six cylinder engines, the dashpot caps were unfinished brass, hexagonal in shape, on later 29D series (after # 6395) and all later engines the caps were black plastic with a wavy outer edge".
Hope this helps,
Mike
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
drooartz MGB Now I should be nice and cool MG 6
