TR2/3/3A what color should it be...?
PatGalvin
OK, a few color questions for the masses?
What color should the bonnet prop rod (including hook mechanism) be painted?
What color should the boot prop rod be painted?
What color should TR3A rear bumper overider brackets be painted? And the long extension tube that rides in the box section?
What color should radiator steady rods (metal rod attaches upper radiator to each wheel well) be painted?
What color should the accelerator pedal assembly be (pedal shaft, bearing housings, and lever)?
Thanks for the tips! My car is far from original but these are easy items to paint whatever color is correct.
Pat
Gordon_Dedrick
The judging Standards are the last word.........but I believe the prop rod is painted the same as the body, the overider brackets are matte black, Radiator steady rods car color, and pedal shaft...........I give up! I think it's black, with the actual pedal natural metal.........but then again I could be wrong...anyone else care to advise?
Gordon
tinman58
chrome!
Jerry
So glad I did not read the Judging standards prior to painting all the little parts. They look better black on my car!
Jerry
vivdownunder
From my own notes -
Prop rod - body color. Safety catch - natural mazak
Boot prop rod - body color
Rear overrider brackets and extn tube - black
Radiator steady rods - black
Accelerator pedal and lever - blackened metal (not paint)
Viv
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
T MGA What color should an MGA brake master cylinder be? MG 6
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
T BN7 wiring diagram in color Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
Rut Bugeye generator color Spridgets 22
simon1966 100 X Brace Color? Austin Healey 16
F TR2/3/3A Wheel Color Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
J TR6 Paint color Triumph 22
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
maxwedge5281 engine compartment color Austin Healey 2
