Should I? [1969 Sunbeam Arrow, aka Hillman Hunter]
Sherlock
A local guy wants to get rid of his old 1969 Sunbeam Arrow, he's pretty much ready to give it away (literally). It runs the 1725cc Rootes Group engine, it has very high mileage (325,000 miles) but has been well maintained thoughout by this guy and much of that mileage is from weekly highway driving - he has owned it for many years and may even be the original owner, he says it still runs very well, and he told me that the only thing that needs to be done to it is some sill work (actually... if I go with collectors insurance, here in Alberta I probably won't even need a safety)
Picture of the exact car he is talking about:
I'm thinking about it, I'm a little leery about the high mileage but at the proposed price...
VitSport6
Re: Should I? [1969 Sunbeam Arrow]
Dunno, James...It has 4 door's kinda boxy, Right up your alley, However I know nothing about them, Looks like it could use a bit more than Just sill work, Unless Canadian for sill work means alot of rust?!?
Good luck
VitSport6
Looking at the pic, If you are smitten I would offer up to $500 Cdn.
Im sure you know what you want and know what to look for, I think its growing on me, Its not a bad looking car...Just stay away from the Scoobie in the background /ubbthreads/images/graemlins/nonod.gif
Once again Good luck /ubbthreads/images/graemlins/grouphug.gif
piman
Hello Sherlock,
I had to look at this post to see what a Sunbeam Arrow is, as I have never heard of it. I can see what is known as Hillman Hunter here in the UK. (Actually Rootes used to rally these internationally)
I echo what others have said, a bit more than sill work, the bonnet and front valance are not good and the old story of tips of icebergs apply, I think.
Good luck.
Alec
Sherlock
Sherlock
Of course I'll take a much closer look before making any decisions... He even indicated that he may be willing to give it away for free if it's going to a "good home"... At the point where the engine and car is (very high mileage) it probably wouldn't be worth doing an extensive restoration, just simply to get it roadworthy and see how much longer it lasts, if I line up collectors insurance all I would need is an appraisal not a vehicle safety
Bruce Bowker
Offer "free" and take it!!!!!
Bruce
waltesefalcon
Plunge in James. Get it as cheap as you possibly can, and drive its wheels off.
Radford
If it's truely a give-away then why not. Sure it needs some work, but if it's near free then why worry. If you decide its too far gone to work with you'll have little or nothing invested.
78Z
go for it! I got around an appraisal on my Spitfire since it wasn't worth a great deal - just had to take some pictures (shouldn't be too hard for you) and give them a value number.
PhilW
I think Canadian for sill work means every bit of sheet metal from your knees down. /ubbthreads/images/graemlins/lol.gif
Go ahead and buy it, give it a few more years before retirement.
P.
aeronca65t
Get it! Why not? (if it's free or nearly so)
I had a Plymouth Cricket (a twin of this car) and it handled well and was a sturdy car. If it runs good, the mileage isn't that critical.
I had a lot of "imperfect" cars in my early years and they taught me a lot. If it needs a bit of work, consider it part of your "LBC education".
I know you are looking for a "starter car" in the area of British sedans...this seems ideal.
sunbeammadd
My first car was a Hunter and it was absolutely bulletproof. I'd say go for it.
By the way, the Arrow/Hunter and the Cricket/Avenger aren't really twins. The Hunter was really an update on the old Minx, while the Avenger was a completely new design. Apart from the odd ancillary item, they share nothing in common. Completely new floorpan, completely new engine.
wkilleffer
If I were in your shoes, and the car was local or near enough that long travel or transport costs were not a problem, I'd take it. If the car's free, I wouldn't even question taking it. If it's a bad car or too much to take on, you can find ways of getting rid of it.
rovernut
James ......I know you are dying to get yourself into something classic but with limited funds and mechanical skills, let alone somewhere to work on it, i would still wait for a bit and find something a little better mechanically that you can just drive ...............That said if it is free and running then you have little to lose do you, but only if it is road worthy and you don't have to certify it...........Good luck Sherlock
Mwalsh
Watch out for the main bearings on this motor. We had an Alpine badged Sunbeam Rapier of the same vintage and I was forever going through the "big ends".
JPSmit
did you buy it?
He didn't. Sherlock pokes his head in occasionally - particularly with lovely photos. Note - the thread is 18 years old.
:cheers:
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
