Should Fans Turn on When AC is on? 1995 VPD
rhull
My cooling fan (2 of them at the Radiator) does not come on when I first start the engine (while the engine is cold) when I have the AC on so no air flows through the AC "radiator" (maybe it's called a condensor) and so, there's not cold air in the cabin.
The Fan does come on once the engine heats up and from then on, even sitting in traffic, the AC blows cold.
Seems to me that the fans should be told to turn on by a switch or relay (or artificial intelligence) whenever the AC is on, independent of the engine temp.
Do you know what might need replaces, or is there some control box that isn't telling the fans to turn on when the AC is turned on?
Thanks for your help,
Bob
Exotexs
Bob,
I'm not familiar with the way the 1995 radiator fans work, but in previous years, they come on when the radiator coolant reaches a certain preset temperature, via a Thermal Switch and Relay.
some of us have modified our XJ-6 (mine is a 1984) to run the auxiliary/electric fan whenever the a/c compressor is turned on.
This works fine in summer for the obvious reason, but in winter, you want the opposite, you want the car to warm up and stay warm when using the Heater.
There are modifications available like you describe, in fact I think there is a kit already to do the above.
try the following site:
https://www.jaggraveyard.com
They sell kits for XJ-6 Series 3 up to 1987. You have a Series 5 XJ-6. Maybe they make one for your model year. If not, let me know and I can refer you to another site.
Ex
LarryK
Ex is right. The system is thermostatically controlled by the A/C ECM. When the temp is right and the A/C on they'll come on. They will not come on cold as the system needs a warm up. It would be useless to by-pass to come on on a cold engine. Have you had a system check recently to see if the A/C pressures are up to snuff and has the coolant been changed in 4 year intervals as recommended?
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
