TR2/3/3A Retorquing the Cylinder Head after the initial torquing.?
glemon
I haven't been here in a while, but ready to jump back in. I always thought you backed off slightly because I was taught (or picked up by osmosis or whatever) that you don't get a good torque reading from a static nut.
That said, after scratching my own head a bit, I think if the goal is to make sure nothing is loose, put a wrench on it and see if it clicks. If the goal is to have as uniform as possible torque specs within standards across all nuts I would loosen and tighten back down.
Will add that in 45 years of British car ownership and lots of heads of and on with Triumphs, MGs, and Austin Healeys I have seen a lot of things break, but never had a head gasket problem. The old cast iron heads are a lot more forgiving than the modern pot metal stuff. You are probably ok doing it either way.
I will add the usual debate I see on this are is if you torque the studs dry and clean or lubed. I think ARP has information on that, but the old factory manuals, is the torque spec. for dry or lubed?
K
karls59tr
Bronze
On the British cars that you did over the years did you always torque dry? I'm assuming they were not ARP which are oiled. I too would be interested to know what the factory manual said as I am replacing the head gasket this Spring and using the stock head nuts and bolts.
glemon
Yeah, standard OEM I always torqued dry. I think there may be tables or engineering guidelines for equivalent torque between dry and lubed. I don't think most of the factory manuals specified, but been a while since I have looked.
Michael Oritt Torquing/Retorquing cylinder head Racing 7
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 0
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
