Reproduction A arm question
G
I bought a pair of Moss' cheaper arms. On the ouside of the bushing housing it is seemsless, but there is a seem or raised area of metal on the inside. Is that supposed to be there? It "seems" that would wear the bushing out quickly. Is it there to make the bushing pivot with the arm?
Jim_Gruber
Pictures please. Jack Laird swears by the more expensive A Arms and I do know the set on Bugsy now came off of a RB Car. Lots more metal in the later A-Arms as well as in the more expensive MOSS A Arms.
jlaird
Spend your money on safety first. You will sleep better nites.
PeterC
There is a bit of the threaded bushing that extends inward to support the cork seals which likewise have 2 different IDs.
Peter
G
Peter
No, on the other end where it bolts to the car.
Jim, this is a RB car.
G
Jim_Gruber said:
Jack Laird swears by the more expensive A Arms. Lots more metal in the later A-Arms as well as in the more expensive MOSS A Arms.
Paid $134 v.s $249 ea
Jim_Gruber
Kelly,
As always you get what you pay for. I think you've noticed already that the less expensive reproduction A Arms aren't nearly as beefy as the OEM A Arms on your 79. That's the difference more metal and cross bracing in the more expensive A-Arms. For normal road use the less expensive ones are fine. If you are Auto-X or using on the track to put some severe strain on the front end spend the money wisely on the parts that keep the front end pointed straight.
Send us pics of the problem you are referring to.
G
Not nessisarily a problem. will grind it out. There is a raised seem on the inside of the bushing housing that would seem to shorten bushing life. No sign of it on the outside.
C MGB-GT Reproduction light switch MG 13
Hangtown Healey Reproduction Shrouds Austin Healey 9
D TR2/3/3A Reproduction TR3A Grille Triumph 63
I Luca P700 reproduction installation Spridgets 7
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
C Recommended reproduction wheels? Austin Healey 29
I Reproduction tachometer drive quality? Spridgets 4
5 4 speed reproduction synchromesh cones Austin Healey 0
angelfj1 Reproduction Lucas Headlamps Triumph 17
W Nice reproduction seat bases Spridgets 0
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
J TR4/4A TR4 reproduction dash pad Triumph 3
sparkydave Darn reproduction parts Spridgets 6
D Reproduction Parts Revisited Triumph 55
angelfj1 Aeroscreen Reproduction Project Triumph 41
D Reproduction Parts Triumph 20
77_MG_Midget MG Midget Reproduction Decals Spridgets 6
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
C Steering Arm Castle Nut Torque Austin Healey 5
WHT Rocker Arm Shaft Replacement Austin Healey 21
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
W Steering Arm Colors Spridgets 1
R TR6 Lower A-arm trunnion bushings Triumph 18
D MGB Rear Suspension Damper Link Arm MG 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
Rob Dodge Trafficator arm issues. Jaguar 2
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
Rut TR4/4A A arm orientation Triumph 2
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
D rocker arm assembly Austin Healey 14
G TR4/4A Wiper Arm Question Triumph 13
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
J BJ8 arm rest with compartment Austin Healey 1
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
A TR5/TR250 Trailing Arm Question Triumph 9
