Darn reproduction parts
sparkydave
Rats! I got my new rear brake cylinders to replace mine that were a little too far gone to rebuild, and the new ones didn't fit! It seems Moss is getting reproductions made by TRW. The ends of the pistons were a little different, but the biggie is that the roll pin that's supposed to keep the thing aligned on the back plate was a good 1/16" off from where it's supposed to be. A little work with some pliers to remove the pin, and it seems to work fine. I think I might be letting Moss know somebody needs to take a closer look at them. I can even send them some originals.
Only snafu on my part was getting it all back together, refilled, and bled, and THEN seeing the two spring washers I forgot to put under the circlips. /bcforum/images/%%GRAEMLIN_URL%%/blush.gif So that's why they seemed a bit loose. Darn, no way to slip those in without opening the lines again. Oh well, it's all good now, and no more leaks /bcforum/images/%%GRAEMLIN_URL%%/driving.gif. Those lines probably needed a second bleeding anyway, right?
PeterC
One of the things that roll pin does is alert you when you are trying to install the wrong cylinder. The bore sizes are different. If having the correct brakes is important to you, I suggest you contact the vendor and ascertain whether you indeed got the correct part. I suspect not. How critical the difference is I can't comment on.
Peter C.
tony barnhill
Great Pumpkin - R.I.P
Peter C is correct...I'm not certain about Midgets but MGB's & MGB GT's have different wheel cylinder bores & the only visible way to tell the difference is roll pin location (it fits into the proper backplate & won't fit the other backplate - to change cylinders you have to change backplates)...either you ordered the wrong number, they sent the wrong number or there's a vendor problem - whichever, the only way Moss can correct the problem is to identify it....give 'em a call with all your information, see what happens.
sparkydave
sparkydave
Ah, I didn't know the dowel pins were located differently to identify different bores. Thanks! I'll get in touch with them and see if we can figure out what it was I got.
4 Stars worth of Smart in my book
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
T Darn you Gerry Coker! Austin Healey 6
M Darn Darn Darn Triumph 38
jlaird Replaced that darn hose today Spridgets 0
T Darn!! Set my car on fire this morning. Triumph 13
AngliaGT Oh....Darn... - Slave Cylinder Triumph 6
jlaird Too darn hot Spridgets 22
pjsmetana Those darn Battery Terminals! Triumph 16
MCNX_BFF Darn woman driver--oh, wait...that's me! Triumph 17
B those darn trunk lids!!! Spridgets 11
Bruce_B Just can't get the darn engine started!!??##HELP!! Spridgets 10
ChrisS Darn oil pan Spridgets 1
7 Darn Pedro struck again Triumph 11
tony barnhill MGB-GT '73 MGB GT - Cryin' Darn Shame MG 5
RickB darn annoying chirpy rattle - FOUND!!! Spridgets 16
WALTER Those darn trunk[boot] cavities Spridgets 9
jlaird Darn PDO Spridgets 3
George Zeck Darn Carbs [I think] ..... Spridgets 3
B Darn Things Follow Me Home. Spridgets 14
sparkydave Darn the ZS carb and inertial starter! Spridgets 0
RobSelina DARN MICE!!!!!!!! Spridgets 30
sparkydave Darn cooling system! Spridgets 11
jlaird Another darn heater question Spridgets 4
jlaird Another darn heater box question Spridgets 6
tahoe healey Darn mud and gravel Austin Healey 20
Bret Darn-it! I hate trim work! MG 4
Howard_The_Duck That gosh darn petro tank! MG 4
mylillooker This DARN steering wheel!! Spridgets 34
C MGB-GT Reproduction light switch MG 13
Hangtown Healey Reproduction Shrouds Austin Healey 9
D TR2/3/3A Reproduction TR3A Grille Triumph 63
I Luca P700 reproduction installation Spridgets 7
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
C Recommended reproduction wheels? Austin Healey 29
I Reproduction tachometer drive quality? Spridgets 4
5 4 speed reproduction synchromesh cones Austin Healey 0
G Reproduction A arm question Spridgets 7
angelfj1 Reproduction Lucas Headlamps Triumph 17
W Nice reproduction seat bases Spridgets 0
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
J TR4/4A TR4 reproduction dash pad Triumph 3
D Reproduction Parts Revisited Triumph 55
angelfj1 Aeroscreen Reproduction Project Triumph 41
D Reproduction Parts Triumph 20
77_MG_Midget MG Midget Reproduction Decals Spridgets 6
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
S importing parts to the U.S. Other British Cars 6
