Reproduction tachometer drive quality?
ichthos
I got an estimate of about $100 to rebuild my tach drive (the part the shaft turns through is worn, so it is not something I can repair). I checked Moss and it costs about $80 for a reproduction tach drive. I admit I am always leary about reproductions. Any advice on which way to go?
Kevin
nomad
Rebuild! Unless the quality has greatly improved the reproductions are IMHO junk!
I have a spare and managed to make a good one out of 2 bad or I would eliminate the mechanical drive before fitting the new replacement.
A replacement drive came on my BE but parts stash saved me!
Kurt
Dug
Kevin,
You have a PM
dug
smaceng
I also wanted an OEM unit for my rebuild. I bought one, opened it up greased it, put it back together. It lasted about 20 seconds when I first started my car....flung it across the garage. I bought a moss unit, and it has been fine ever since!
Scott in CA
DRH
I separated a BE tach drive, cleaned it up, redrilled the fastener holes, lubed it up with molybdenum grease, used small bolts to assemble it and it has been working well for a couple of years now.
C MGB-GT Reproduction light switch MG 13
Hangtown Healey Reproduction Shrouds Austin Healey 9
D TR2/3/3A Reproduction TR3A Grille Triumph 63
I Luca P700 reproduction installation Spridgets 7
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
C Recommended reproduction wheels? Austin Healey 29
5 4 speed reproduction synchromesh cones Austin Healey 0
G Reproduction A arm question Spridgets 7
angelfj1 Reproduction Lucas Headlamps Triumph 17
W Nice reproduction seat bases Spridgets 0
John_Nichols Triumph Surrey Top Window Plastic Reproduction Triumph 3
J TR4/4A TR4 reproduction dash pad Triumph 3
sparkydave Darn reproduction parts Spridgets 6
D Reproduction Parts Revisited Triumph 55
angelfj1 Aeroscreen Reproduction Project Triumph 41
D Reproduction Parts Triumph 20
77_MG_Midget MG Midget Reproduction Decals Spridgets 6
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
