TR2/3/3A Replacing Lockheed Axle Seals 56 TR3
CJD
I don't think so...The brake back plate also serves as the bearing retainer, if I remember right. I guess it may be possible to leave the brake shoes assembled on the plate as you remove it, but I think it would be more trouble than just removing the brake shoes to gain access to the backplate bolts. Now, once the backplate is removed, you can pull the hub, axle, and bearing out together.
Nanhook
Thank you John, I ll remove it! but the axle shaft will go out when I ll remove the brake back plate?so easy?or need to open the differential?
CJD
If you look at the breakdown illustration above, you can see that the bearing slides onto the axle, followed by the hub. Once installed, the hub locks the bearing onto the axle. Then, not shown, is that the brake backplate retains the bearing outer race, and holds the seal that rides on the lip of the hub. So, once the brake backplate is removed, the bearing is free to slide out. On Steve's differential it was stuck from years of gummy build-up, but there is nothing solid holding it in. There is no axle lock in the center pumpkin on the Lockheed...it simply slides into the splines. The ball bearing (not a tapered bearing) does all the work of holding the axle in place.
The Lockheed axle was weaker than the later Girling and it leaked, but it was much easier to service than the Girling. You could easily carry a spare axle and a handful of tools, and change the axle in less than an hour on a clean differential.
Nanhook
Actually you was right, I am in front of bearing quite easily but, now I am not sure the problem is the bearing , can be is the hub my problem?I mean, hub is not very thigh to the shaft axle and I find few metal dust…
Nanhook
If I only could post a smal video I could show hub move on shaft axle
CJD
If you look closely inside the hub, you will see a split about an inch inside the splines. That is where the locking collar is still in the hub. You should be able to catch it from the back side with a punch ( or gently on the outside) and tap it out.
The locking collar is tapered on the outside, to center the hub. As you tighten the hub nut the collar centers the hub, and as you continue to tighten the nut, the collar compresses onto the axle splines, locking the hub to the axle. It is possible the nut was not tightened properly.
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
