TR2/3/3A Rebuilding TR3 Fuel Pump question
RedTR3
I have an original TR3 fuel pump with priming lever that I am rebuilding to keep as a spare. I have the rebuild kit.
But in removing the old diaphram, I kind of mangled the oil seal when I removed the diaphram shaft. (I should have paid closer attention to what I was doing!) This seal is apparently NLA but I have heard that it is not really necessary. Is this true?
martx-5
Depends on where you got the kit from. I just re-did mine, and the kit I got from The Roadster Factory did contain the oil seal. However, I've read on this forum that guys are just putting back what ever is left of the seal and have not run into any problems. When I took my pump apart, the rubber part of the seal was basically non-exsistent, yet the car ran fine when I shut it down for the restoration.
I'm sure some others will chime in with their experiences.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
donbmw
I did mine but it did not have the seal and I still have the leak, removed and installed new pump with out lever.
Don
TR3driver
Great Pumpkin - R.I.P
The seal's only purpose is to help keep fuel from running into the crankcase if the diaphragm fails. So it's not essential for ordinary operation (but IMO is a good idea).
As noted, TRF found a source & is supplying the seal in their rebuild kits. Since older kits may not be compatible with modern fuel, buying a new kit is probably a good idea anyway.
But I found an old brake seal that worked pretty good when I rebuild my original pump. Sorry, no idea where it came from.
MGTF1250Dave
I agree with Randall, replacing the seal can do no harm if you have one. The diaphragm is very stout so a puncture is a very remote possibility in my opinion. I have used the TRF rebuild kit in a spare pump I have and did use the seal. The newer replacement pumps (without the priming lever) do not come with the seal.
Geo Hahn
I too rebuilt the pumps w/o the seal and w/o any problem. If you do not have a priming lever pump on the engine now you may want to put that 'spare' you're rebuilding on the car. I find the lever very useful for refilling the bowls if the car has had a long sit.
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
N TR2/3/3A TR3 Gauge Rebuilding Triumph 6
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
mountainman TR2/3/3A TR3 Carb Rebuilding Service Triumph 2
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
