    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 Question on TR6 trunnions and inner tie rod ends
gbtr6
Hi All,
Haven't been on in quite a while. The Six has been running great, but I've had a persistent shimmy at @ 60-65. I replaced the ball joints, wheel bearings, and got trunnion pivot and bushing kits also. Didn't replace the whole trunnion. Ball joints were needed, as well as the trunnion kits, I still need to do the bushings for the A arms. The questions are, on the trunnions, where the upright threads into the trunnion, on one side it was snug with no play, the other wobbled abit. I took the stop off and turned the upright til it was snug like the other side. I hope that's a correct procedure. All seems in order. It has better feel and less shimmy. Next, the inner tie rod ends. They seem a bit loose. Can I replace only the innards, from Vitoria British, or replace the whole rod?
Thanks,
Perry
The manual has instructions on the trunnion fitting, but I do not believe they should be fully snug. Doing this from hazy memory so double check / wait for others to jump in here.
Inner tie rod = what the steering rack gaiter cover, yes? I don't believe they should have any noticeable play.
Perry:
I had one inner tie rod perished. I figured at 35 yrs old the other would likely fail also. Inner tie rods will set you back about $60 apiece from Moss or TRF. Moss sells a new rack for $180 and TRF sells rebuilts for $299. I bought a new Moss unit that I will install this winter. Made sense to me to get a whole new assembly for only $60 more than a pair of tie inner rods would cost me. If I had my time back I would have bought the Quick Rack but too late now so I will be installing the new rack with solid aluminum mounts and rebushing the steering column. I hope to get a good result. Good luck with yours.
Cheers,
Thanks for the replies. I will have to check on the tire balance issue. That may be a mitigating source of vibration, especially as it's only at that speed range of 63-65. I'll probably wait til spring to do anything else now, but will check on the work I have done to make sure everything is snug down.
Thanks,
Perry
Perry, double-check the alignment as well. I had a shimmy at 60 until I adjusted the tie rod ends. Now I can take my hands off the wheel @ 70mph! :shocked:
Thanks for the reply. I checked all the items I replaced for tightness and the wheel bearing on the passenger side had loosened up, can't figure that out. But, tightened up and all is pretty snug. I do need to have the tires balanced probably, and an alignment wouldn't hurt either.
Thanks,
Perry
E TR6 TR6 flip-up bonnet question Triumph 4
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
B TR6 TR6 1976 Clutch Choice Question Triumph 3
J TR6 TR6 Differential Rebuild question Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
J TR6 TR6 Brake Question Triumph 1
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
sundown TR6 1973 TR6 flasher question Triumph 6
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
S TR6 Quick TR6 alternator question Triumph 6
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
I TR6 75 TR6 vacuum hose question Triumph 2
B TR6 1972 tr6 orignality question Triumph 3
W TR6 carb question tr6 Triumph 1
M TR6 TR6 Master Cylinder Rebuild Question Triumph 10
I TR6 TR6 paint question Triumph 8
Coyote1 TR6 TR6 Header Rail Question Triumph 4
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
B TR6 TR6 Boot Cover Question Triumph 4
G TR6 TR6 caliper/hose fitment question [VB] Triumph 3
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
S TR6 TR6 Bumper question ?????? Triumph 3
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
hondo402000 TR6 TR6 Clutch question Triumph 5
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
W TR6 TR6 Differential Question. Triumph 6
T TR6 Question on TR6 throw out assembly Triumph 9
W TR6 TR6 Timing chain oil seal question Triumph 3
R TR6 Front TR6 Suspension Question... Triumph 7
wangdango TR6 TR6 solex question? Triumph 16
B TR6 This question is for the TR6 restorers...... Triumph 7
CinneaghTR TR6 TR6 Lower Wishbone Arm Question Triumph 3
Z TR6 Question about rebuilt TR6 calipers Triumph 3
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
