Plug wires 101 - need help
TexasTD
Well, I thought I knew how to assemble a spark plug wire until last night. I got a set for the '52 TD from Moss Motors and began the assembly. The end that screws into the distributor cap seems pretty easy. I stripped the insulation back about 1/8", bent the end over and soldered the brass washer on the end. The boot that goes over the spark plug has a hole with a set screw to secure to the center conductor (I'm assuming). Well, once I hooked it up (only doing 1 wire for now to make sure I do it correctly), it does not fire. However, when I pull the boot off of the plug, I can see the spark jump to the plug and it fires. Once I push the boot over the plug, we're amiss again.
This is my dad's TD and I'm tinkering on it so he can sell it. Kinda hard to let someone test drive it with only 3 jugs firing.
Any suggesstions?
Thanks,
Eric
Put some lube on the wire, slide the boot back and connect the wire to the plug, and see what it acts like. If everything is good, slide the boot back down. Sometimes when you hook the wire up with the boot down, you don't actually connect the wire to the plug.
Jeff
Well, after much trial and error, swapping wires and finally swapping plugs, looks like I had a bad plug. I pulled the wire off the plug and it arced real strong and the cylinder fired. The closer to the plug I got with the wire, the lower the force of the spark. So, I'm off to AutoZone for a new plug. Hope it works...
Thanks for the reply.
Eric
Jeff,
Yep, Champions. Ran to the local parts store last night and picked up the last one they had. I looked in the locker box next to the battery this morning and found 4 new ones (Champion) that my dad had forgotten about. Is there something I need to know about Champions before I replace the other three? (Feel this one coming....)
Eric
Hi Eric,
I'm obviously not Jeff but I'll throw in a comment anyway.
Champion is the only plug that I have consistently had trouble with in 50 years of car tinkering. I don't know why, they look just like other plugs, although for some reason they seem to have narrower heat range tolerances.
The classic was when I had an engine misfiring & replaced the plugs with Champion. It didn't help anything. I eventually replaced the coil, points, plug wires, & my underwear, but it still misfired. In desperation, I took it to a friend's shop that had an ignition scope. He informed me that I had a couple of bad plugs. I asked how can that be, the plugs are brand new? He said it happens quite often with Champion plugs. He offered to put in a set of NGK's & not charge me if it didn't fix the problem. I had to pay for the new plugs.
In encounters with various other cars & motorcycles over the years, I have had more trouble with Champion plugs than all of the rest of brands put together. (I did have a lot of trouble with a set of Holley plugs once. Maybe made by Champion?)
I have never had a problem with NGK plugs & use them exclusively. Your experience may vary.
Dave pretty well put any comments I would have in a nutshell. Thanks, Dave. /ubbthreads/images/graemlins/grin.gif
In my 38 years of LBC ownership, I've found the NGK plugs to be the way to go.
Jeff
C MGB New plug wires and distributor cap MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
J General Tech I Need a Set of Plug Wires! Help! Triumph 14
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
drooartz MGB Which plug wires go where... MG 5
M Restoring proper order to spark plug wires Triumph 36
wingsandwheels TR6 green plug wires, '74 Tr6 Triumph 6
JohnnyO Dist cap and plug wires Spridgets 6
Musicman Spark Plug Wires Triumph 10
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
bigjones Plug wires - anything of quality out there? Spridgets 27
T Could it be bad plug wires? MG 3
1 Spark plug wires gone 'haywire' Spridgets 16
B Plug wires Jaguar 7
H Plug wires for electronic ignition Austin Healey 18
emann plug wires for Pertronix? Spridgets 6
tosoutherncars Q - spark plug wires Spridgets 3
Got_All_4 TR2/3/3A TR3A Spark Plug Wires Any Good Ones Out There? Triumph 11
K Best spark plug wires with Pertonix:what to use? Racing 1
K "Bumblebee" spark plug wires....... Triumph 10
ronzet A Shocking experience -- Pulling plug wires MG 25
AUSMHLY Spark plug wires Austin Healey 8
danielnorton Spark plug wires Spridgets 6
Luke_Healey Generic plug wires? Spridgets 13
Woodie spark plug wires Spridgets 2
Woodie bosch spark plug wires Spridgets 5
C Spark plug wires MG 14
nathandarby67 Bumblebee Plug Wires MG 29
C Plug wires Triumph 9
drooartz Plug wires revisited Spridgets 12
T Cut/Splice Spark Plug Wires?? Triumph 13
W Replacing spark plug wires Restoration & Tools 1
Simon TR4a Spitfire Spitfire plug wires Triumph 2
R plug wires Other Cars 3
tahoe healey spark plug wires Austin Healey 11
1 Plug Wires MG 7
D Copper core plug wires MG 3
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
