Oil Pressure Valve
aeronca65t
Not sure what device you're talking about.
Do you mean the oil pressure relief valve?....or the oil pressure sending unit?
jlaird
Why if it works ok?
dklawson
On the A-series engines the relief valve is indeed the valve with the domed nut and the long spring underneath.
On transverse engine A-series cars it's common to replace the standard plunger/spring valve assembly with a ball bearing, shortened spring, and adjusting knob (modified) dome nut. So much debris gets in the oil system of the transverse engines that using the ball minimizes problems with the relief valve and the adjusting knob lets you dial in your oil pressure.
I wouldn't think it necessary on an inline engine. Still... it's a fun little change.
fmichaels
i changed that spring during the rebuild but it looked and felt like the old one. cheap insurance i guess.
JerryB
would it be a good idea to replace the oil pressure valve assembly?
Certainly wud B a good idea to examine the bullet taper for abnormal wear and the spring for good tension. Unless you have a new spring for comparison that would B a hard task tho. Unless current stoks from the usual suspects are NOS the afteramrket pieces will be highly suspect.
Very easy to modify the holder/cap for adjustability of the spring if necessary.
Platinum
And *do* do it while the engine's out... it is a ~Genuine Booger~ to replace, engine in situ.
J Oil Pressure Relief Valve Austin Healey 3
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
K Oil pressure or balance valve on top of Purolator Triumph 1
T Oil Pressure - correcting relief valve problems Spridgets 3
L oil pressure relief valve removal Spridgets 10
RJS Oil Pressure Relief Valve - Proper Function Triumph 2
T AH 3000 Oil Pressure Relief Valve - Spring Length Austin Healey 4
L CAP NUT--OIL PRESSURE RELIEF VALVE Austin Healey 2
Trevor Jessie Oil pressure relief valve Spridgets 5
BOBBYR Oil pressure relief valve? Austin Healey 32
prb51 TR2/3/3A TR3 oil pressure relief valve Triumph 3
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
F TR6 Oil Pressure Relief Valve- TR6 Triumph 2
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
