AH 3000 Oil Pressure Relief Valve - Spring Length
twas_brillig
We have a 62 BJ7 that has about 65000 miles on it and has been stored since the mid-70s. Oil pressure is a bit below 20 psi at idle (using 20-50 Penrite, if memory serves).
I ordered a replacement relief spring and relief spring cup from AH Spares in the UK, based on the possibility that the engine was losing pressure due to oil bypassing the spring cup (due to a weak spring or worn cup). Order placed Dec. 15 and received the 23rd (via air letter).
The Haynes "Austin Healey 100/6 and 3000 Owners Workshop Manual" (date of publishing unknown) that I have advises that the minimum length for the spring is 2.87 inches. THe Bentley reprint of the original Healey workshop manual doesn't mention this dimension.
My 'old' spring is about 2 11/32 (2.344) inches long; the new one is about 2 5/8 inches long (2.625), so I've gained a bit more than a quarter of an inch, but am still a quarter inch shorter than the Haynes reference.
The angle of the 'cone' on the new cup appears to be slightly more tapered (ie more shallow; less blunt) than the original; the base on the original has a slight chamfer that is missing on the replacement - I think I'll smooth the resulting 90 degree edge a bit with a whet stone.
I'll install the new bits and advise if there's any change in my oil pressure.
And hopefully I haven't betrayed any etiquette by mentioning brand names.
Later,
Doug
RF Thom
Doug Had a similar problem. Utilizing Shell Rotella 30HD, at 180F after a long run I had 45 PSI, but the delta at idle was too great dropping to 15 PSI. Bought a new spring no measurable change. Sorry but I didn't measure the free length. What I did do was take the brass end cap and drill & tap a 5/16-24 thread in it. Then I took a 5/16-24 set screw and silver soldered a spring pilot on the end and reinstalled. Now with a 1/2" wrench and allen key I can turn the screw in to gain idle oil pressure - progressively three [3] turns brought the idle pressure up to 23 psi, and slightly raised the running pressure closer to 50 PSI. level. Also inspect the relief valve for wear and measure the clearance in the hole. This is to prevent leakage past the valve which returns oil into the sump, not the by-pass circuit. Mine had wear and some scuffing on the O.D. so I measured the hole and machined up a new one with 0.003" clearance.
Regards, Bob
GregW
T
twas_brillig
Eureka!
Installed the new spring and cup last night; re-installed the spin-on oil filter assembly (had removed it to ensure that the gasket lined up etc; had to use the tap and die on the bolts and the block; used a magnetic pickup to pull some of the debris out of the block bolt holes); fired her up with some paper over the rad to get the temperature up (we've got about a foot and a half of snow on the ground and temperatures to match) and...
oil pressure at idle of 600 rpm and temperature of 195 to 200 F was 45-50 psi; at 2500 rpm, it was 55 psi.
Looking forward to confirming these numbers this summer.
Quite happy about this pretty cheap fix, as I don't have the skills Bob has. Greg -thanks for the note regards the other thread also.
Doug
britman
just a thought. I did not replace the bearings in the rocker shaft when i rebuilt my BJ7 and I have the same low oil pressure readings at idle after being at speed.
bd
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
Healey Nut 3000 oil sump pans Austin Healey 16
J 3000 bj8 Oil Pump Austin Healey 38
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
C 3000 gearbox oil Austin Healey 4
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
SkinnedKnuckles Question about AH 3000 carb damper oil Austin Healey 21
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
davidb AH 3000 spin on oil filters Austin Healey 13
B Oil Capacity 3000 Austin Healey 36
ronzet Spin-On Oil adaptor for AH 100-6 and 3000 Austin Healey 9
GregW 3000 oil leak from side of engine Austin Healey 29
D 3000 Oil Burner Austin Healey 1
R Oil Pump Replacement 67 3000 Austin Healey 3
D 3000 MK1 Engine Oil Leak Austin Healey 8
C 3000 oil presssure / gauge Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
