3000 Oil Burner
dcmasters
I just had new intake and exhaust valves, seats and guides replaced in my head. The No. 6 exhaust valve face had a chunk broken out of it.
The shop that actually did the head work has been doing this for years so I assume they got the guides reamed right and the "o" rings re-installed.
A compression check done after re-installation shows about 150 PSI in each cylinder and the plugs are all uniformly black. The car burns oil like a mosquito fogger now. It didn't do this before the head rebuild.
At first I thought of a cracked or worn ring problem but it seems to me that would show up in a compression check.
HELP!!! Does anyone out there have any advice.
Thanks in advance,
My guess would be that since you no longer have the compression bypassing through the valves, you're getting blowby past worn rings. I had the same thing happen to me once, on a non-LBC.
What kind of compression did you have before the valve job, and how many miles are on the rings?
Does it smoke constantly, or only under vacuum conditions, such as decelleration, or at a shift point? If its under vacuum, it would point towards excessive clearance on the valve guides, or maybe improperly installed, or missing valve seals. I doubt the latter though, as if the guide clearances are correct, you wouldn't notice any smoke this early.
Run it with the oil filler cap off, and see if you can detect any pressure coming out of the crankcase. This indicates blowby.
A cylinder leakdown test will pretty much tell you where the problem is.
I'm sure I've forgotten something, but no doubt someone else will remember it!
Jeff
[ 11-23-2003: Message edited by: Bugeye58 ]</p>
Healey Nut 3000 oil sump pans Austin Healey 16
J 3000 bj8 Oil Pump Austin Healey 38
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
C 3000 gearbox oil Austin Healey 4
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
SkinnedKnuckles Question about AH 3000 carb damper oil Austin Healey 21
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
davidb AH 3000 spin on oil filters Austin Healey 13
T AH 3000 Oil Pressure Relief Valve - Spring Length Austin Healey 4
B Oil Capacity 3000 Austin Healey 36
ronzet Spin-On Oil adaptor for AH 100-6 and 3000 Austin Healey 9
GregW 3000 oil leak from side of engine Austin Healey 29
R Oil Pump Replacement 67 3000 Austin Healey 3
D 3000 MK1 Engine Oil Leak Austin Healey 8
C 3000 oil presssure / gauge Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
