oil pressure relief valve removal
Lewpok
I cannot get the valve plunger out of the block of my 73 1275ccMidget. Everything else came off uneventfully for a change. Any ideas?
Platinum
Tapered paint stirring stick. Whittle it down to fit thru the bore yet wedge in the plunger. Another way is with a telescoping "pen" magnet.
Getting it all back INTO place is the real challenge. That spring gets harder to compress the longer it takes you to get the threads started. :jester:
jlaird
I should think a dowl tapered on the end would do the trick.
I have always used an ice pick.
L
Lewpok
neither the tapered paint stick or telescoping magnet worked. The magnet just gets longer so the plunger doesn't move freely, the reason for the replacement. maybe an ice pick will get it free
Platinum
Wow. It must really be stuck in there!
P'raps a wire coat hanger with a short kink in the end, say 1/2""V" to wedge into the I.D. of the plunger?
jlaird
Is engine out of the car? If so air pressure into the oil pump hole should pop it out.
There's drain hole directly below the pressure regulator, that release oils directly into the oil pan once the regualator is maxed. I try some some wd40 and blow compresed air in the drain/release hole, that should giggle it loose.
dklawson
Or... run a tap into the plunger and pull it out. Replace it with a new plunger when you put the relief valve components back in the block.
jlaird
Those are great ideas. I replaced mine with a ball bearing. Needed to adjust spring length but solved that with an adjustable oil pressure spring cap.
L
Lewpok
It took a 1/4in NPT tap to get it out. It had more taper than the other taps that were available. I had to screw it in a couple of turns or it pulled loose. It took a lot of effort to work it out. The new plunger went in pretty easily compared to this; I hope the new spring is the right length.
Later, I plan to toast all of you that made suggestions. Thanks!
Billm
You may want to take the seat out and get it surfaced a bit too-
Pretty easy to tap it with a 5/16 either fine or coarse thread and then pull it out with a long stud.
BillM
J Oil Pressure Relief Valve Austin Healey 3
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
max71 MGB The easy way to get the oil pressure relief cap nut back on MG 8
H Purolator oil pressure relief spring Triumph 1
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
T Oil Pressure - correcting relief valve problems Spridgets 3
RJS Oil Pressure Relief Valve - Proper Function Triumph 2
T AH 3000 Oil Pressure Relief Valve - Spring Length Austin Healey 4
L CAP NUT--OIL PRESSURE RELIEF VALVE Austin Healey 2
Trevor Jessie Oil pressure relief valve Spridgets 5
BOBBYR Oil pressure relief valve? Austin Healey 32
prb51 TR2/3/3A TR3 oil pressure relief valve Triumph 3
F TR6 Oil Pressure Relief Valve- TR6 Triumph 2
ChrisS Adjustable oil pressure relief Spridgets 10
S Pressure Relief Spring & red line oil Austin Healey 13
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
J Zero oil pressure at 4000 RPM Austin Healey 24
