MX5 engine in B
69MGC
Has anyone run across someone who has put a Mazda MX5 engine and trans into a B?
If it fits I was thinking of dropping one into my project car.
aeronca65t
Just a comment: most swaps take an enormous amount of dedication.
And often, they do not add to the value or fun of the car.
That said, the Miata swap into an MGB makes more sense than most engine swaps.
Carl Heideman did one for Grassroots magazine. He did it correctly and with a skilled worker, an excellent shop and proper tools, it turned out to be a big job.
Anyway, here's a link to Carl's job:
https://www.eclecticmotorworks.com/miatab.html
https://www.eclecticmotorworks.com/miatab2.html
You can find more at this link (lower left side of page)
https://www.eclecticmotorworks.com/previousbritish.html
jhorton3
The Eclectic B GT is the only one that I know of. Someone else has a MGA with a MX-5 engine and transmission fitted. I think there was a good bit of modification and fabrication needed for the swap. To my knowledge there aren't any prefab conversion kits.
If you're wanting to fit a completely different drivetrain in perhaps you could look into some V6 or V8 conversions. There are at least kits that help with fitting them in.
aeronca65t
I meant to say this before: if you really want to have a modern Miata engine, why not just leave it in a Miata! And keep your MGB as well.
There are plenty of Miatas cheap and still decent. I've seen them in the $2500 range and even some "runners" in the $1000 range.
Just a thought....
<span style="font-size: 8pt">(I have an MGB and a Miata.....a nice combo actually)</span>
69MGC
69MGC
All good info. Thanks guys. Can't say that I am all that keen on the looks of the Miata, but I hear the engine is a screamer. I had thought about putting in a V6 or V8 but both of my B's are early models and I don't relish the thought of doing extensive engine compartment mods to make one fit.
Perhaps some day I will get a later model and drop in a V8.
I had my 72 B engine completely rebuilt so maybe I should just put that back in the car and do an engine swap on some future car.
Thanks for all your advice.
kev
MGZT260
If it's power you are looking for - beyond what a back to factory spec B engine will do then some thoughts:
*cross-flow head with appropriate weber carb
*super charger
*"C" six-cylinder engine - you know that will fit will minimal parts which are probably all available form Moss or VB, coming up wit hthe engine is trickier
G
gblawson
One of our club members put a 'rotary' in his B.... little thing screams and looks pretty tiny in the B's engine bay....
billspohn
*super charger
"You know that will fit" ???? Are you serious? The factory couldn't put the C series engine in there without changing evey internal body panel forward of the firewall, AND changing the whole front suspension to a completely new torsion bar set up. I think the old saw "Don't try this at home" surely applies here.
Couple of other things. If you fit a crossflow head with 4 intake ports no one but an idiot (they are out there) would fit 'a 'Weber carb', which indicates a single downdraft, although many have fitted two sidedraft Webers (even though a pair of SUs is the better choice for street with that head).
The supercharger, however, is an excellent bolt on performance improver!
The Miata engines are an excellent option, but with a lot of do it yourself skill and time. A friend has done one MGC and at least a couple of MGBs - here's a pic of his MGA:
The OP shouldn't be put off the V6 route if that's what he wants to do. The kits are available for reasonable money to fit one with T5 trans to an MGB, and there isn't that much extra that needs to be done to relieve a couple of spots in the tighter tunnel on the early cars. Get in touch with one of the vendors to get details.
The minimal mods needed to put the V6 in an early MGB pale in comparison to the major work needed with the Miata transplant.
MGZT260 said:
<snp> "C" six-cylinder engine - you know that will fit will minimal parts which are probably all available form Moss or VB, coming up wit hthe engine is trickier
Sure...you can fit a C block into the MGB...but you're going to need to change the front crossmember, take a look at the front suspension (the MGC uses a torsion bar suspension and tube shocks up front), a new slam panel, alter the firewall, find a C bonnet....etc, etc, etc....almost easier to do a V6 or V8 conversion!
billspohn
<span style="font-weight: bold">Almost</span> easier?
Hmm - cut off all the car in front of the windscreen and come up with something else that works, including torsion bar mounts under the seats, or bolt in a V6 mount kit in less than a day......... :lol:
You knew what I was implying. :angel:
MGZT260
Okay, okay, it would be easier to score a C that had been rearended and mate it up to a B from the firewall back - and even then that is not a bolt-on application but a job for super-welder because of full unibody construction. But even until the end challenging engineering concepts never stopped the factory from converting V6 fwd Rover-based sedan into rwd ZT260 with Mustang 5.0 V8's up front.
I have a V8 project myself in the wings, deciding on whether to follow through or save it for something else. The Maxda twin-cam somehow looks exactly right in that A. Maybe...
glemon
Waren't both the original miata and original MGA twin cam motors 1.6 liters, I see some symmetry there....an MGA twin cam with a modern trouble free motor, best of both, know swaps are a lot of work, have looked pretty deep into it, been scared off, it is not so much the blacksmiths work of fitting the motor, but making the rest of it work right and not look and drive like a chop job. Instruments suspension and brake balance.
I have seen some very well done conversion but probably a few more not so well done.
tony barnhill
Great Pumpkin - R.I.P
The old MG World magazine (before it went out of circulation) had an article about an early B into which had been transplanted a modern twin cam engine.
jmc948
Another option would be to boost the power of what you have, which would probably be cheaper and less hassle than a transplant. And it wouldn't be very hard to match the output of the 1600 Miata with good reliability.
Dave Headley at https://www.fast-mg.com/ does good work. Full disclosure: I'm a friend of his.
Jim
JPSmit
This month's Classic Motorsports has the outcome of their MG Midget restore/ update project. It beat the Miata around the track by about 3 seconds
tony barnhill
Redoing the original engine with some performaqnce items is always less expensive that fancy transplants...not to say fancy transplants aren't fun.
billspohn
I don't know how to break this to you, but an MGC from the firewall back <span style="text-decoration: underline"><span style="font-weight: bold">IS</span></span> an MGB.
So like I said, just use an MGC and forget about the MGB.
tony barnhill
Actually, an MGC from the firewall back isn't an MGB....the torsion bars go beyond the firewall, the front floorboards are different, etc.
I don't know why the desire to convert an MGC specifically when there's so many reasons not to....later MGB's are almost a "drop-in".
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
M MGB MX5/Miata seats for MGBGT MG 2
G 1994 MX5 Miata Other Cars 6
TR3driver Miata/MX5 Steering wheel repair Other Cars 7
L General Tech Engine id Triumph 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
