MGB MX5/Miata seats for MGBGT
Mcfish
Hi there
Does anyone have a template to make up seat rails to fit Mx5/Miata seats to fit to my 1980 MGBGT. 140 dollars plus postage to the uk seems incredibly expensive and wondered if it's possible to knock some up at home
regards
mcfish
69MGC
I fitted some Miata seats into a 68 GT. What I did was to straighten out the Miata Rail attachment points and made up some metal blocks to raise the seat up off the floor and then used some heavy duty bolts that I had from a seat belt retro kit for a 65 Mustang. Worked great. A bit of fiddling and I'm sure you could do the same, maybe even better.
Gokart
How have you got on with your seat problem McFish?
I have not done them but want to and my research leads me to believe that once the Miata seat mounts are moved (straightened) so they are flat with the floor it is a matter of taking a template of the B floor holes and the miata seat holes. Then tranfer the markings onto some 6mm flat bar and bolting the bar to the floor and then the seat to the bar.
The bolt heads protruding from the underside of the flat bar for the seat to mount onto are absorbed by the carpet.
Google it and you will see.
Cheers Rob
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
G 1994 MX5 Miata Other Cars 6
TR3driver Miata/MX5 Steering wheel repair Other Cars 7
69MGC MX5 engine in B MG 24
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Raymond MGB Miata seats? MG 1
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
G MGB Miata seats MG 4
NutmegCT MGA MGA/Miata MG 12
jhorton3 Replacecment Miata Seat Covers Spridgets 12
BobbyD Miata Seat Brackets..... a new approach Triumph 0
Sarastro A "bugged" Miata Spridgets 4
Brosky Wedge Miata seats now in TR8 Triumph 8
Darrell_Walker Wedge Miata seats in a TR8 Triumph 45
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
CZ_Dave MGB Miata Seats in a MGB? MG 10
G TR6 TR6 with Miata seat recover Triumph 21
A TR6 TR-6 need Miata seat adaptors Triumph 2
RickB Need info about Miata seats in Spridget Spridgets 49
DART Need MIATA HELP!! Other Cars 8
R MGA Miata Battery in MGA MG 11
t_bush Miata seats and a rollbar? Triumph 9
DNK Miata Seats Triumph 16
philman Wedge Miata Seat installed in a TR7V8 Triumph 10
Brosky Miata seats 98% INSTALLED! Triumph 16
zedvictor1 Miata powered Sprite Spridgets 7
Brosky Miata Seat Up-date -- Progress!! Triumph 9
Brosky Miata Seat Up-date Triumph 0
A New Miata top, finally. Other Cars 8
Brosky Miata seat prep continues Triumph 48
