MK IX Differential Ratio
Michael J.
Can anyone tell me what the axle ratio is for the MK IX?
Is that stamped somewhere on the Housing?
Was the MK IX a limited slip differential or like the earlier models?
AlanT
The automatic transmission rear axle ratio is 4.27:1 . The overdrive IX (very rare) is 4.55:1. The 4.09:1 ratio as well as the Thornton Powr-lok differential were available 'special order only'.
The ring and pinion tooth count are found on a plate retained by a lower inspection cover bolt. Should it be a limited slip a tag with 'PL' will also be attached.
Alan T
R Changing BJ7 Differential Ratio Austin Healey 10
F Differential Ratio Sunbeam (Rootes) 3
vping Differential Ratio Spridgets 15
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
