Missing Plate
jsfbond
after cleaning up from last years flood here in Vermont, I do not find this plate. 1970 missing plate.jpg
I am missing a few things that may have gone down the river towards Connecticut.
  • :upset:
If you guys down stream could look around a bit for a tote full of car parts...that would be great.
Is there a source for this plate as a reproduction?
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
H Missing Oil Filter Spring Plate Austin Healey 2
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
kurts100 Am I missing something? Triumph 8
