Ignition rotor recommendations - odd failure
Andy65
Driving in 1st gear, uphill, BJ8 dead slow and the engine quits and wouldn't restart. Test light showed power to the points. Check wires. The ignition rotor looked absolutely fine. But no spark at the plug. Replaced rotor and off we go. I don't know what brand the failed rotor is but it says "Made in W Germany" so that indicates how long it has been in use.
- Who makes a good rotor? I remember some were junk.
- Have you ever seen one fail when it looks fine? I don't see any hairline cracks or a loose rivet.
I've heard good things about these, but I haven't tried them cuz I have a Mallory. Advanced Distributors
Who makes a good rotor?-----"Pertronix"-- :laugh:
I remember some were junk.------ Most of them are!!!
:savewave:
Many times they short internally to the rivet then to the distributor shaft that is at Chassis GND.
If you want to alleviate this problem and use readily available rotors.
Buy a new rotor remove the rivet and the spring clip, fill the void left where the rivet was removed with JB Weld.--Fwiw--Keoke
Moss has Lucas and "aftermarket". Anything better out there? This West German one has a rivet with a threaded hole in the center of the rivet head. What's with that?
Yes a"Pertronix"----Keoke-- :laugh:
Probably more trouble-----Same GUY-- :smile:
Yes I can also swear to using the Moss "premium" rotor, 1 1/2 years no problem. Bought two, keep one in trunk for a spare, have had to loan out my spare to other's twice.
Yes I can also swear to using the Moss "premium" rotor.
:savewave:
I told you to get a Pertronix Johnny--Keoke- :jester:
Hi Andy65,
With a CD ignition and after installing a hot coil, I purchased (2) Advanced Distributor rotors for $15 when rotors from others manufacturers were in question. I installed the first rotor and kept the second in the glove box just in case. For the past three years of commonly shifting at around 5K I have had no misfires or any other ignition issues.
I am definitely satisfied with the rotors from Advanced Distributor.
Ray (64BJ8P1)
Hi Andy - Get the red rotor from Advanced Distributor - it's made a big diference for my 100-6. and even my sprites.
Thanks Keoke, in fact I do have a pertronix but never installed it. Couldn't really see a need for it.
:savewave:
Put it in and yee shall see the need!!!----Keoke-- :laugh:
RJS Fouling Ignition Rotor Triumph 7
tahoe healey ignition rotor Austin Healey 1
RobT Second Failed Ignition Rotor in 100 miles???? Triumph 14
G TR2/3/3A Ignition Issues Triumph 5
D Ignition Timing Austin Healey 9
Bocaray TR2/3/3A 123Ignition Triumph 12
Ohiobugeye Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ? Spridgets 15
R Ignition Failure Austin Healey 24
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
