HVDA conversion
fad64b
Just a few questions for those experienced with the HVDA conversion. I am planning to install the toyota trans in my TR3, I just purchased a used gearbox with 90k on it.
1. What is the recommended gear oil for the W58 gearbox?
2. I see the drain plug on the bottom of the gearbox but where do you add the oil?
3. Is there anything else I should do to the transmission before installing??
Thanks
I can't help with 1 & 2, but I would pull it apart before installing it in my car. Those units are really built well, but you never know how it's been driven and 90K is a definite mile marker for a tear down / inspection before installing again.
I really do not want to tear down the gearbox that's why I took my time to find a low millage (90k) with a good front bearing and tight shifter bushing.. I was hoping there are enough members on this site with these 5 speed conversions that would chime in with there experiences..
I bought a remanufactured one. Cost was close to 1k (more with shipping). It sat for more than the warranty period before being installed, and when it went in leaked oil like crazy from the rear seal. A new one had to be fitted, which meant that it had to come back out.
If you got one that doesn't leak, and that feels fine change the oil and put it in. Given my experience, you can hardly do any worse!
I'd use GM Syncromesh Fluid..available from many sources and brand names.
It seems that this stuff works pretty good in all manual transmissions with and without OD.
I purchased a rebuilt w58 Toyota trans for $900.
Peace of mind? I hope.
Before you do the HVDA conversion, be aware of the
specifications of the clutch stack height. The instructions tell you about that.
Be sure to use a throw-out bearing that Herman recommends.
My trans shifts great, although at idle speed, there is some "whirring" sounds from the trans or t.o bearing which I
cannot identify.
cannot identify.
Hmmm, Paul, I bet you are an expert on "whirring" sounds from a throwout bearing, eh?
Tell ME MORE about the "wirring" sound from the t.o. bearing.
What do you know?
Please, please.
Is there a t.o. disaster in my future
I don't have a whirring sound in mine.
And as far as the technical aspects of the installation, I had someone else do it. He was dubious about the process but found that it went in pretty easy. Mine was his first, but has done several since.
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
D Things you NEED to know before an HVDA Conversion Triumph 6
fad64b HVDA conversion Triumph 12
WidespreadPanic HVDA Toyota Tranny conversion: alternatives? Triumph 24
M TR2/3/3A HVDA Speedometer Drive Triumph 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
PeterK General TR HVDA and Celica 5-speed hearbox Triumph 4
2wrench TR6 Hvda will not move into gear Triumph 7
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
2wrench TR6 Installing HVDA transmission. Triumph 8
PatGalvin TR2/3/3A TR3a HVDA gearbox cover fit issue Triumph 7
gubba Help anyone with HVDA Triumph 6
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
fad64b TR2/3/3A TR3 starters and flywheels HVDA Triumph 11
gubba Finally my HVDA is in ! Triumph 45
prb51 HVDA 5 speed tranny Triumph 18
P Generator-to-Alternator Conversion Austin Healey 7
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
M MGB 1967 MGB starter conversion MG 9
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
AndreL TR6 Conversion to electric fuel pump Triumph 14
mctriumph TR2/3/3A Ultimate fan conversion Triumph 14
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
